Different Charging System
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=5925
Author:  Ace [ Mon Nov 09, 2009 12:36 pm ]
Post subject:  Different Charging System
I know there has been lots of posts about the stator charging system on the MM's. I know the GT's don't start charging back into the battery until 2000 r's. Question: Is there a different aftermarket stator that will charge as soon as you start the motor? I do a lot of idling and such and it beats up a battery pretty bad. Comeback FE's!
Author:  froghunter [ Mon Nov 09, 2009 12:56 pm ]
Post subject:  Re: Different Charging System
I do a lot of frogging and I have checked into that also, the only answer I got was that you need to run the engine for about 30 minutes. I was told that you can get a larger amp one but all takes about 2200 rpm to start charging.
Author:  brlcla [ Mon Nov 09, 2009 6:18 pm ]
The new marine grade charge 20 amps at idle and 50 amps above 2000 rpms.... may be able to retrofit your engine depending on age of the motor.
Author:  dog walker [ Mon Nov 09, 2009 6:39 pm ]
Author:  LA OUTLAW [ Tue Nov 10, 2009 7:07 am ]
I was told by the mechanic for prodrive in franklin, LA that it was not possible to retrofit them with the new charging system.
Author:  jpc014 [ Wed Nov 11, 2009 3:55 pm ]
Author:  OwenDickeson [ Wed Nov 11, 2009 6:00 pm ]
Author:  deadbird8 [ Thu Nov 12, 2009 7:25 pm ]
