It is currently Thu Sep 18, 2025 6:36 am
Reply to topic  [ 8 posts ]
 Different Charging System
Post Different Charging System
I know there has been lots of posts about the stator charging system on the MM's. I know the GT's don't start charging back into the battery until 2000 r's. Question: Is there a different aftermarket stator that will charge as soon as you start the motor? I do a lot of idling and such and it beats up a battery pretty bad. Comeback FE's!
Ace
Cajun Performance 1854/GTR35 Tiller (Lil Daddy Mods)
Mon Nov 09, 2009 12:36 pm
Post Re: Different Charging System
I do a lot of frogging and I have checked into that also, the only answer I got was that you need to run the engine for about 30 minutes. I was told that you can get a larger amp one but all takes about 2200 rpm to start charging.
Homemade 18' X 48" with HD 4000 Mudbuddy and looking for more
Mon Nov 09, 2009 12:56 pm
The new marine grade charge 20 amps at idle and 50 amps above 2000 rpms.... may be able to retrofit your engine depending on age of the motor.
Mon Nov 09, 2009 6:18 pm
Mon Nov 09, 2009 6:39 pm
I was told by the mechanic for prodrive in franklin, LA that it was not possible to retrofit them with the new charging system.
1754 GT EXTREME 37EFI
Tue Nov 10, 2009 7:07 am
Wed Nov 11, 2009 3:55 pm
Wed Nov 11, 2009 6:00 pm
Thu Nov 12, 2009 7:25 pm
