Adapter?? http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=6044 |
Author: | Drake_35GTR [ Mon Nov 16, 2009 1:29 pm ] |
Post subject: | Adapter?? |
I currently have a EVT intake with the Mikuni carb.... I know for a fact that I'm getting to much air the motor for the little bit of mods that I have because if I dont roll into the throttle slowly, it will have a bog that doesnt go away until I let off the throttle and then roll back into it. I want to experiment with my stock intake and an adapter. Where can I get or who can I contact to get a hold of an adapter to go from my stock intake to the Mikuni carb?? |
Author: | Rail [ Mon Nov 16, 2009 2:11 pm ] |
Post subject: | Re: Adapter?? |
Depends on which Mikuni carb you have.. I had an adapter CnC'd and cost about $125 w/ the 3rd shift discount.. If you're using the Super BN then talk to Hoyt.. He was making them in the beginning.. |
Author: | deadbird8 [ Mon Nov 16, 2009 3:49 pm ] |
Author: | basinhunter [ Mon Nov 16, 2009 3:51 pm ] |
Sounds like the carb needs to be adjusted? |
Author: | JD [ Mon Nov 16, 2009 6:14 pm ] |
Do a search for "scary fast power" they make a insert for mikuni and other carbs. It makes them act like a spread bore. They are well made and cost about 100 bucks the dirt bikers like them a lot.IT helps bottom end and mid range, If you are running a heavy load a gear change would help but you will loose top end. You may be giving it too much or not enough from the acc pump setting. Until I put in the scary fast plate noting helped my bottom end with the 45 mikuni,stock had a better hole shot, but no midrange . JD |
Author: | Drake_35GTR [ Mon Nov 16, 2009 9:22 pm ] |
I'm not fimiliar with an accelorator pump..... And how do I figure out which mikuni I'm running? 42, 45 or 48? |
Author: | Rail [ Tue Nov 17, 2009 8:11 am ] |
Author: | Drake_35GTR [ Tue Nov 17, 2009 10:23 am ] |
Author: | deadbird8 [ Tue Nov 17, 2009 1:02 pm ] |
I would take that as you don't have a tuning manual. www.mikuni.com- HSR Tuning manual. |
Author: | Rail [ Wed Nov 18, 2009 7:01 am ] |
http://www.googleisyourfriend.net/index.html |
