| Wix filter p/n http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=61248 |
| Author: | SETx Longtail [ Mon Apr 13, 2015 7:15 am ] |
| Post subject: | Wix filter p/n |
New rig is ready for her first oil change, can't seem to find the Wix number for the filter I need, I've searched. I'm assuming it's the same as any other big block Vanguard. This is for my 37 EFI |
| Author: | HOTSAUCE170 [ Mon Apr 13, 2015 7:20 am ] |
| Post subject: | Re: Wix filter p/n |
| Author: | BayouBuster [ Mon Apr 13, 2015 7:40 am ] |
I use #51438. |
| Author: | txmudcutter [ Mon Apr 13, 2015 7:53 am ] |
viewtopic.php?f=3&t=46207 Here"s a thread with the numbers for several brands of filters |
| Author: | SETx Longtail [ Mon Apr 13, 2015 10:02 am ] |
| Author: | SETx Longtail [ Thu Apr 16, 2015 8:03 am ] |
Turns out that a Napa 1056 filter is made by WIX (says on the box) and is a couple bucks cheaper. I picked up a case of them this morning and a case of oil. Should be good to go for a while |
| Author: | justooln2 [ Sun Feb 19, 2017 10:28 pm ] |
57035 Wix OEM replacement for B&S 842921 Filter 51348 Has a Larger capacity and better filtering, though the tradeoff is a higher bypass pressure. (sort of) Part Number: 57035 UPC Number: 765809570351 Style: Spin-On Lube Filter Service: Lube Type: Full Flow Media: Enhanced Cellulose Height: 2.305(59)* Outer Diameter Top: 2.923(74)* Thread Size: 3/4-16 By-Pass Valve Setting-PSI: 8 Anti-Drain Back Valve: Yes Beta Ratio: 2/20=20/41 Burst Pressure-PSI: 275 Max Flow Rate: 7-9 GPM Nominal Micron Rating: 32 Part Number: 51348 UPC Number: 765809513488 Style: Spin-On Lube Filter Service: Lube Type: Media: Enhanced Cellulose Height: 3.404(86)* Outer Diameter Top: 2.921(74)* Thread Size: 3/4-16 By-Pass Valve Setting-PSI: 8-11 Anti-Drain Back Valve: Yes Beta Ratio: 2/20=6/20 Burst Pressure-PSI: 275 Max Flow Rate: 7-9 GPM Nominal Micron Rating: 21 Capacity: 7 |
| Author: | SETx Longtail [ Sun Feb 19, 2017 11:32 pm ] |
I've gone to the 51348 since this post. All those napa filters get used on the lawn mower at the rate of one a year |
| Author: | MaXXis85 [ Mon Feb 20, 2017 7:09 am ] |
I use briggs, But I do get them at a good rate. For resell that is LOL |
