It is currently Thu Sep 18, 2025 12:10 pm
Reply to topic  [ 2 posts ]
 Honda gx670
Post Honda gx670
Anyone have a manual for the 24hp gx670? I need an engine diagram that shows the carb. Is there an overflow on the side of the motor? I was running the other day and my LT basically slowly shut down. There are no holes in the engine but gas flows from the side of the carb when I prime the motor. Any info. would be great, duck season just started in FL and I am stuck!
Finally 15x46 Express w/ 24 hp Bevertail
Sun Nov 22, 2009 8:40 pm
Post Re: Honda gx670
Okay just went through this, you are gettin fuel to the carb correct? On the bottom side of the carb is a 12+ activated solenoid, carefully tear into that and look closely at the plunger solenoid assembly. Mine was sticking closed- keep in mind when you turn the key on and touch the solenoid assembly to the motor frame the solenoid should pick effortlessly. I suspect ethanol was causing mine to stick. Pm me your e-mail address and I will send you the PDF I have found on Honda GX670 motor.
Paul
Tue Nov 24, 2009 5:24 pm
