Honda gx670
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=6153
Author:  AcolemrcU [ Sun Nov 22, 2009 8:40 pm ]
Post subject:  Honda gx670
Anyone have a manual for the 24hp gx670? I need an engine diagram that shows the carb. Is there an overflow on the side of the motor? I was running the other day and my LT basically slowly shut down. There are no holes in the engine but gas flows from the side of the carb when I prime the motor. Any info. would be great, duck season just started in FL and I am stuck!
Author:  postalpaul [ Tue Nov 24, 2009 5:24 pm ]
Post subject:  Re: Honda gx670
Okay just went through this, you are gettin fuel to the carb correct? On the bottom side of the carb is a 12+ activated solenoid, carefully tear into that and look closely at the plunger solenoid assembly. Mine was sticking closed- keep in mind when you turn the key on and touch the solenoid assembly to the motor frame the solenoid should pick effortlessly. I suspect ethanol was causing mine to stick. Pm me your e-mail address and I will send you the PDF I have found on Honda GX670 motor.
Paul
