curcio13085
 Jetting a 36hp pro drive
I am supposed to be getting a pro drive next week from tennesse. Who can re jet it close to baton rouge for our elevation? It has a stage 3 kit on it so I want someone to get it running right. Also how much cash should this cost?
_________________ 20x60 homemade with twin Prodrives JH Chopper (YLM)if I have time will make a SH
| Wed Dec 02, 2009 9:40 am |
basinhunter
Joined: Tue Jan 13, 2009 6:22 pm Posts: 1642 Location: Morgan City, LA
 Re: Jetting a 36hp pro drive
You can do it yourself, very easy and takes 5 minutes. What size jet does the carb have in it?
_________________ Pro Drive m'fers
| Wed Dec 02, 2009 9:41 am |
curcio13085
The guy doesnt know about the carbs.
| Wed Dec 02, 2009 10:03 am |
basinhunter
Whenever you get it look under the carb, there is a nut. Take the nut off and the main jet is there, can't miss it. Take the jet out and the number is stamped on it, the jet that's in there might be fine. Run it first and see what you get.
| Wed Dec 02, 2009 10:06 am |
curcio13085
Thanks I will. All the horror stories on the stage 3 got me nervous on using it. Im not hard on my stuff but dont want it to break at 50 hrs. I might sell it but for this duck season I will def use it.
| Wed Dec 02, 2009 10:18 am |
Wilson
Joined: Thu Jan 15, 2009 6:35 pm Posts: 935 Location: South LA
Call Andy Johnson, the Boat Dr., in Metairie. He will be able to help you. His phone number is 504-737-1203.
| Wed Dec 02, 2009 4:57 pm |
bayouboy
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5376 Location: Venice, La
I wouldn't sell it, If it was me the first thing I would do is get a thicker head gasket or trade/sell the stage 3 heads in for some stock ones and shim the stock valve springs. your gonna want to try and get that compression down.
200 psi or below if possible.
As for your jetting carb issue, Basin and Wilson just about covered it. the Mukuni's HSR 42mm are sweet setups and real user friendly.
| Wed Dec 02, 2009 11:25 pm |
deadbird8
Here's the tuning manual- very simple to tune. You access the main jet through the 17mm bolt in the bottom of the fuel bowl. BoatDr sets them up with 165 main jets in the 42MM carbs. http://www.mikuni.com/pdf/hsr_tuningmanual_021003.pdf
| Thu Dec 03, 2009 7:37 am |
