It is currently Fri Dec 19, 2025 8:53 pm
Reply to topic  [ 21 posts ]
 K&N Air filter for 36 HP VANGUARD
Post K&N Air filter for 36 HP VANGUARD
Anyone know the part number. That e-4665 looks a little small.
Thanks
Wed Sep 30, 2009 8:09 pm
Post Re: K&N Air filter for 36 HP VANGUARD
I PUT A E-4521 IN MY 35 HP MUD BUDDY AND IT FITS GREAT I THINK A 36 SHOULD TAKE THE SAME FILTER.
18X48 HANKO W/35 HP MUD BUDDY 30.6 M.P.H.(KICKIN' A$$ AND TAKING NAMES) I'M YA HUCKLE BERRY
Wed Sep 30, 2009 8:23 pm
MMT Moderator
GTB 1860 w/ 2019 GTR40XD-HO
Wed Sep 30, 2009 8:31 pm
MB AND GT DEFINETLY TAKE THE SAME I AM SURE OF
Wed Sep 30, 2009 8:33 pm
MMT Moderator
Wed Sep 30, 2009 8:35 pm
THE ONLY BAD THING IS THAT THEY ARE A SPECIAL ORDER I HAD TO ORDER MINE FROM AUTO ZONE IT ONLY TOOK A DAY TO COME IN IT COST 38 DOLLARS
Wed Sep 30, 2009 8:37 pm
save your $$ it won't change shit!! Take the old 1 trow it in the garbage and put the cover back on !! ;)
17x48 extreme stage 2 GTR
Wed Sep 30, 2009 8:38 pm
MMT Moderator
Wed Sep 30, 2009 8:40 pm
I HAVE HEARD ALOT OF PEOPLE SAY THEY DON'T EVEN RUN A AIR FILTER AND NEVER HAVE. I DON'T THINK WILL DO THAT I WILL RUN THE K&N AND BE HAPPY WITH THAT
Wed Sep 30, 2009 8:41 pm
Wed Sep 30, 2009 8:42 pm
when I switched to the mikuni I pulled my k&n out and it was dirty.
Mostly from mud getting sucked into the intake. so you can get mud and dirt in there, but do what you want its your motor, whatever makes you feel safe.
When in doubt, throttle out.
18x60 prodrive w/36 prodrive
Wed Sep 30, 2009 9:29 pm
I noticed on my stock filter I have a paper element and a foam wrap around it. Might be benficial to remove the foam?
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Thu Oct 01, 2009 10:26 am
MMT Moderator
Thu Oct 01, 2009 10:30 am
Werd panty hose works well as a water repellant while muddin.
Bayou Surface Drive
337-351-0362
Thu Oct 01, 2009 12:23 pm
So which one is it on the 36HP vertical??? I would love to put a K&N on my unit. I think most of the dirt and dust will come while trailering down my states wonderful WMA roads.
I was thinking of just getting a dust cover like a Carb flute cover. While running I do not think you will get much. A filter of some sort seems prudent. I worked for Donaldson Filter and you would be surprised what is in the air. :shock:
I do think a VERY free flowing filter is the way to go. Just the Foam wrap on a blank fliter housing( take the paper out) would be enough.
Mine has oil on it from some engine work and I need to replace it. I want to go order the K &N.
What is the right part # for a 36 Vertical K&N??
No good deed goes unpunished
Tue Oct 13, 2009 5:53 am
viewtopic.php?f=3&t=41 :idea:
Tue Oct 13, 2009 6:50 am
Gator Trax 1854 ran over by drunk driver!! ( boat less)
Tue Oct 13, 2009 8:32 am
Tue Oct 13, 2009 8:53 pm
I typed the wrong #, my bad.
I just ordered the E4521 from amazon.com for $28.55 free shipping and no tax. had the E-4665 in my 18 mb, put it in my 35, it was loose. that's all I know. I will try the E4521.
both briggs 18 and 35 take the same stock type air filter.
Wed Oct 14, 2009 2:37 pm
So which # filter is it? and can you see a difference?
36pd pushing a 1860 Hawks fiberglass. If you scared say you scared
Sat Oct 24, 2009 9:42 am
E4665.
I bought the E4521 first from Amazon, and the stock air filter housing on the PD will not close all the way with this filter. I returneed it and got the E4665, and it fits perfect for the PD 36.
Tue Dec 01, 2009 10:37 am
