Go-Devil HELP!!!! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=6239 |
Author: | iron man [ Sat Nov 28, 2009 4:35 pm ] |
Post subject: | Go-Devil HELP!!!! |
I have a 20hp go-devil that runs at full speed when out of the water but bogs down to less than half throttle in the water and it starts backfiring a little after a few minutes of running. what is causing this? need some answers quick. i already brought it to the go-devil place once 2 weeks ago and its not going again unless their work is warrantied. |
Author: | Gigafowl [ Sat Nov 28, 2009 4:41 pm ] |
Post subject: | Re: Go-Devil HELP!!!! |
Sounds like it is runing on only one cylinder.... Try removing one plug wire at a time while running - bet you get no change when one is removed and engine dies when other one is removed... Cylinder where there is no change is mis-firing or not firing at all... |
Author: | spiderbeaver [ Sun Nov 29, 2009 6:20 pm ] |
take your carberator apart go to auto zone pick up b12 carberator cleaner in a gallon soke it for a day after soaking spray through all jets and put the carberator back on |
Author: | postalpaul [ Sun Nov 29, 2009 7:34 pm ] |
Honda I will assume, clean the fuel cut off solenoid on bottom of carb. |
