It is currently Thu Sep 18, 2025 12:12 pm
Reply to topic  [ 4 posts ]
 Go-Devil HELP!!!!
Post Go-Devil HELP!!!!
I have a 20hp go-devil that runs at full speed when out of the water but bogs down to less than half throttle in the water and it starts backfiring a little after a few minutes of running. what is causing this? need some answers quick. i already brought it to the go-devil place once 2 weeks ago and its not going again unless their work is warrantied.
Sat Nov 28, 2009 4:35 pm
Post Re: Go-Devil HELP!!!!
Sounds like it is runing on only one cylinder....
Try removing one plug wire at a time while running - bet you get no change
when one is removed and engine dies when other one is removed...
Cylinder where there is no change is mis-firing or not firing at all...
Eat - Sleep - Hunt ! ! !
Sat Nov 28, 2009 4:41 pm
take your carberator apart go to auto zone pick up b12 carberator cleaner in a gallon soke it for a day after soaking spray through all jets and put the carberator back on
1752 rooky boat 35 GDSD
Sun Nov 29, 2009 6:20 pm
Honda I will assume, clean the fuel cut off solenoid on bottom of carb.
Sun Nov 29, 2009 7:34 pm
