It is currently Tue Mar 31, 2026 6:19 am
[ 7 posts ] |
Troywaterfowler
 Mudbuddy 37 EFI
Hey all. Just got a new Prodigy 1751 with a Mudbuddy 37 EFI. I only have about 3 hrs on it, so still doing the break in. My question is, once I get it broke in good, what is the normal RPM's I should keep it at high speed? I've stretched it out a couple times and got up to 4000 RPM's or so and then backed off pretty quick. I've done a little cruising around and usually hang about 3200 or so, which is ok speed, but not too fast. This is my first mud motor so I just want to do everything right. Thanks for the help.
| Thu Sep 17, 2015 8:44 pm |
brycecheramie
 Re: Mudbuddy 37 EFI
| Thu Sep 17, 2015 9:02 pm |
hunt-chessies
Joined: Thu Sep 08, 2011 10:55 am Posts: 86 Location: Jacksonville FL
 Re: Mudbuddy 37 EFI
let her eat and post up what your getting for performance!!!! I have a 1854 Prodigy with a 37 EFI that should be done in a week or two. very curious what the performance will be like. I have it in my mind as the perfect balance of speed, power, and load capabilities. Find out soon. the 1748 was my first choice but the guys on MMT talked me out of that.
_________________ 1854 Prodigy with a 37 EFI HDR Owned by a Chessie... HR "A Hunters Dream Of Westwind" JH (HUNTLEY)
| Fri Sep 18, 2015 2:39 am |
MaXXis85
 Re: Mudbuddy 37 EFI
The best thing for a break-in is to vary RPM's from mild to wild. Basically if you are running bayou's and slough' it is a good combination because you are on and off the throttle a lot. Run that unit WFO and see what she got.
| Fri Sep 18, 2015 6:48 am |
North LA Hunter
Joined: Mon Aug 02, 2010 8:39 pm Posts: 6976 Location: West Monroe, LA
 Re: Mudbuddy 37 EFI
| Fri Sep 18, 2015 6:52 am |
Troywaterfowler
 Re: Mudbuddy 37 EFI
Thanks for the replies guys. Gonna put some good hrs on it this wknd and I'll post what it does. Thanks again.
| Fri Sep 18, 2015 12:57 pm |
ALLDRAKES
 Re: Mudbuddy 37 EFI
1750 Beavertail with 600lbs of guys and 2 troling motors ran 22.5 with the 37EFI HDR.......alone it ran 29mph. Picked up 3 mph from .5 hour on motor to 2 hours with the load. Havent ran solo since.
| Sun May 07, 2017 6:12 pm |
[ 7 posts ] |
