| Mudbuddy 37 EFI http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=63744 |
| Author: | Troywaterfowler [ Thu Sep 17, 2015 8:44 pm ] |
| Post subject: | Mudbuddy 37 EFI |
Hey all. Just got a new Prodigy 1751 with a Mudbuddy 37 EFI. I only have about 3 hrs on it, so still doing the break in. My question is, once I get it broke in good, what is the normal RPM's I should keep it at high speed? I've stretched it out a couple times and got up to 4000 RPM's or so and then backed off pretty quick. I've done a little cruising around and usually hang about 3200 or so, which is ok speed, but not too fast. This is my first mud motor so I just want to do everything right. Thanks for the help. |
| Author: | brycecheramie [ Thu Sep 17, 2015 9:02 pm ] |
| Post subject: | Re: Mudbuddy 37 EFI |
| Author: | hunt-chessies [ Fri Sep 18, 2015 2:39 am ] |
let her eat and post up what your getting for performance!!!! I have a 1854 Prodigy with a 37 EFI that should be done in a week or two. very curious what the performance will be like. I have it in my mind as the perfect balance of speed, power, and load capabilities. Find out soon. the 1748 was my first choice but the guys on MMT talked me out of that. |
| Author: | MaXXis85 [ Fri Sep 18, 2015 6:48 am ] |
The best thing for a break-in is to vary RPM's from mild to wild. Basically if you are running bayou's and slough' it is a good combination because you are on and off the throttle a lot. Run that unit WFO and see what she got. |
| Author: | North LA Hunter [ Fri Sep 18, 2015 6:52 am ] |
| Author: | Troywaterfowler [ Fri Sep 18, 2015 12:57 pm ] |
Thanks for the replies guys. Gonna put some good hrs on it this wknd and I'll post what it does. Thanks again. |
| Author: | ALLDRAKES [ Sun May 07, 2017 6:12 pm ] |
1750 Beavertail with 600lbs of guys and 2 troling motors ran 22.5 with the 37EFI HDR.......alone it ran 29mph. Picked up 3 mph from .5 hour on motor to 2 hours with the load. Havent ran solo since. |
