Re: 29 kawasaki fuel pump help!!
I couldnt ever find one that I felt comfortable using. They pressure is supposed to be 27psi at 3600rpm. It has a pressure regulator on it so I assume the max pump pressure would be a little more than that. All the inline aftermarket pumps that I could verify the actual pressures around that were around $150 from parts stores. Them they didnt seem to match the fuel volume I needed. I ended up goomg back with a factory on just like what was on it I found new for $225. I didnt want to run the motor to lean or rich on accident so I just felt more comfortable that way.
If you read the reviews there is a guy that claims he has has ran this pump on his mower without issues
http://www.amazon.com/Airtex-E8445-Univ ... B001BFOBXALet me know what you decide or what you come up with. I looked all over the place and couldnt come up with one aftermarket
