Electric Fuel pump??
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=63828
Page 1 of 2
Author:  Mudhole [ Wed Sep 23, 2015 12:06 pm ]
Post subject:  Electric Fuel pump??
I'm going to install the e pump I bought a while back in my 32 Prodrive
Here's my setup, two tanks up front, 5/16 line to the primer bulb, then into the fuel/water sep, then to a inline fuel filter, then to the stock 32 fuel pump, then to carb!
Where's the best place to put the e pump? Was thinking I'd take the primer bulb out and put it in its place!
And do you by pass the stock pump? Is so, how? Remember this is a 32 Prodrive and it has the mech pump that goes thru the block!
Author:  MaXXis85 [ Wed Sep 23, 2015 3:03 pm ]
Post subject:  Re: Electric Fuel pump??
After your primer, but before your inline filter. You can bypass the pump if you like or you can pump through it.
Author:  Mudhole [ Wed Sep 23, 2015 3:33 pm ]
So should I take out the water sep??
Author:  MaXXis85 [ Wed Sep 23, 2015 3:48 pm ]
Author:  Mudhole [ Wed Sep 23, 2015 4:21 pm ]
So yours is between the primer bulb and the fuel/water sep?
Author:  MaXXis85 [ Thu Sep 24, 2015 6:36 am ]
Fuel is filtered better under pressure than under vaccum. I say Primer, Water Separator, Pump, In line filter. Just my opinion.
Author:  Frog [ Thu Sep 24, 2015 7:08 am ]
gonna jack the thread here. What pump do you like best? The one I have has not worked properly since it was new.
Author:  MaXXis85 [ Thu Sep 24, 2015 7:37 am ]
Author:  Russ [ Thu Sep 24, 2015 8:49 am ]
I'm on my second facet cube. Nice pump. Different motor, hence the second one. The other one is still working fine.
Author:  Mudhole [ Thu Sep 24, 2015 5:01 pm ]
I got the Mr Gasket a while back! Was running the river last weekend, mine would start to loose speed, ran ok on like 3/4 throttle, then would eventually die! Could pump the bulb, and it'd run for a while then eventually die again! Had more problems outta mine in the last couple years than ever!!!
Author:  MaXXis85 [ Fri Sep 25, 2015 5:50 am ]
I bet that will fix the issue.
Author:  Mudhole [ Sat Sep 26, 2015 11:20 am ]
Y'all post up some pics of how your e pumps are! And where you got em installed in your fuel lines!
Author:  Russ [ Sat Sep 26, 2015 11:50 am ]
Mine is 6 inches from the tank. I don't even have to squeeze the bulb.
Author:  Mudhole [ Sat Sep 26, 2015 1:48 pm ]
Tanks in front???
Author:  Russ [ Sat Sep 26, 2015 3:51 pm ]
Yep. 16ft of fuel hose after the pump.
Author:  flint87 [ Wed Feb 17, 2016 6:32 pm ]
You guys that are putting the e pump inside the boat, are you wiring it to its own switch or are you wiring it to the ignition. If you're wiring it to the ignition, what wire?
I got the mr gasket pump from oreillys and it's pretty big. Can't figure on anywhere to mount it on the motor
Author:  JD145 [ Wed Feb 17, 2016 6:54 pm ]
Author:  flint87 [ Wed Feb 17, 2016 7:10 pm ]
Author:  JD145 [ Wed Feb 17, 2016 7:44 pm ]
Non CDI. I was thinking the 35s had those solenoid too. My bad, ive got a stock carb down at the shop, i should have looked at it
Author:  flint87 [ Wed Feb 17, 2016 9:36 pm ]
I just need to find a hot wire coming off the ignition and mount this giant fuel pump on the side of the motor I guess?
Author:  brycecheramie [ Wed Feb 17, 2016 9:43 pm ]
Author:  flint87 [ Thu Feb 18, 2016 6:19 am ]
Author:  reharbert [ Thu Feb 18, 2016 6:20 am ]
Try the yellow wire. It's typically a keyed accessory circuit. Worked on mine.
Sent from my SAMSUNG-SM-G890A using Tapatalk
On both my predator 670 and subaru efi
Author:  richard nagon [ Thu Feb 18, 2016 12:30 pm ]
Filter than pump for me. I also use a relay going to pump from switch.that way I have the voltage I need and am not taking it away from another circuit. Also use a oil pressure switch wired in. Do that if pressure goes away pump shuts off. Wire size is very important. Especially with a long run. And cold temps.
Author:  MaXXis85 [ Thu Feb 18, 2016 1:21 pm ]
Typically it is the Gray wire on briggs harness.
Author:  Melnmo [ Thu Feb 18, 2016 3:06 pm ]
Noob here.. is something going on that you have to run a fuel pump or is it for "peace of mind?"
Author:  flint87 [ Thu Feb 18, 2016 4:22 pm ]
It was the red wire on mine.
Author:  flint87 [ Thu Feb 18, 2016 4:23 pm ]
Does the fuel pump HAVE to be 12" from the tank? I would rather mount it on the inside of the transom so I don't have to run all that wire.
Author:  brycecheramie [ Thu Feb 18, 2016 4:53 pm ]
Author:  MaXXis85 [ Fri Feb 19, 2016 7:41 am ]
Author:  flint87 [ Fri Feb 19, 2016 8:00 am ]
Author:  flint87 [ Fri Feb 19, 2016 8:02 am ]
Author:  MaXXis85 [ Fri Feb 19, 2016 8:06 am ]
Doubt it man.
Author:  SETx Longtail [ Fri Feb 19, 2016 8:51 am ]
When I ran that Mr Gasket pump I mounted it on the transom. Make sure you throw a spare in the boat. Those things seem to take a dump at the absolute worst time. Also, the pressed in threads will seep fuel over time. I never ran the facet pump but always wanted to try it. Sold the boat before I got around to it.
What's the outlet pressure on the stock Briggs EFI lift pump? Seems like that would be maybe a more reliable solution.
Author:  MaXXis85 [ Fri Feb 19, 2016 9:54 am ]
Author:  SETx Longtail [ Fri Feb 19, 2016 3:31 pm ]
That's what I was thinking. Gotta be less than 5. I'd give it a try. I don't think they're real expensive either.
Author:  Russ [ Fri Feb 19, 2016 3:33 pm ]
Low psi pumps for efi aren't exactly the norm. Both the Kawa and the Kohler use something in the 25ish range. So it doesn't exactly "gotta be" less than 5 lol
I only say that so you confirm before you go buy pumps.
Author:  cb5331 [ Fri Feb 19, 2016 3:39 pm ]
Geeeeettt outta here boy. Nobody talking 'bout efi 'round here.
Author:  Russ [ Fri Feb 19, 2016 3:55 pm ]
Setx was.
Page 1 of 2 All times are UTC - 6 hours
