Carb/speed adjustment on Kholer 25 http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=64343 |
Author: | Bayport [ Thu Oct 29, 2015 10:37 am ] |
Post subject: | Carb/speed adjustment on Kholer 25 |
I got a new carb on my motor and am getting 3700 out of the water...have yet to test in water, will do this weekend. Idles around 1100. I've messed w the governor screw but cannot seem to get any more rpm out of it. I was hoping for 4k out of the water appreciate any suggestions. |
Author: | Gunshinestate407 [ Thu Oct 29, 2015 6:07 pm ] |
Post subject: | Re: Carb/speed adjustment on Kholer 25 |
I had a similar issue with my 23 Briggs. I could only get 3400 rpms. Ended up adjusting the throttle cable where it connects to the carb. There was a little slack in the throttle cable so it wasn't able to open up all the way when at WOT. Make sure ur throttle cable doesn't have a lot of slack in it. Sent from my iPhone using Tapatalk |
Author: | Will C [ Thu Oct 29, 2015 9:47 pm ] |
There is an adjustable small bolt with nut on or near the rotating part of the throttle linkage. You should be able to turn it up |
Author: | Bayport [ Fri Oct 30, 2015 5:52 am ] |
Yea, tried that one. Does not seem to make a difference at least OOTW I'd post a pic if it was easier on here |
Author: | Will C [ Fri Oct 30, 2015 7:55 am ] |
Isnt ther also a tang to bend up or down to let linkage swing farther. I dont have one in front of me. If nothing else put a ziptie in and around the gov spring, and u did check cable as stated above? |
Author: | Bayport [ Fri Oct 30, 2015 7:57 am ] |
Have yet to check cable but will...thx for the info |
Author: | Bayport [ Sun Nov 01, 2015 3:57 pm ] |
Ran it today Only getting 2950-3k w light load on a 14x36 I pulled the air filter and checked the throttle linkage When I take it to full throttle I see that it opens all the way for a brief second and then the spring on the throttle linkage pulls it back and then getting about 3600 out of water I can manually put it wide open and get up to 4100 I don't know enough about this while governor and linkage to understand what is controlling / limiting this Gonna take it to a small engine shop and see if they can resolve it |
Author: | Russ [ Sun Nov 01, 2015 4:17 pm ] |
You can put a zip tie on the gov spring. Start with about half of the coils. See how that does, then add more if you need to. You want that engine around 4500 or so out of the water. Should run 4k or so with a light load (maybe a hair less on that boat since it's not very wide). |
Author: | Stinkymud [ Sun Nov 01, 2015 5:36 pm ] |
Author: | Bayport [ Mon Nov 02, 2015 8:22 am ] |
Ok, Carb for dummies! Which spring, which tab? thx a lot LT |
Author: | Will C [ Mon Nov 02, 2015 8:42 am ] |
The screw with lock nut is in top of pic, u turn this in, the spring has a zip tie already in the end only, you can grab alot more of spring with new ziptie, also looks like your cable has limited throw. You have to look at both ends and make a judgement call on how to address that. |
Author: | Bayport [ Mon Nov 02, 2015 8:53 am ] |
I missed that zip tie..thx I have adjusted that screw w the nut on it w/o any change... I'll try to grab some more of the spring w a new sip tie and wait for Stinkymud to reply wrt the tab LT |
Author: | Will C [ Mon Nov 02, 2015 9:09 am ] |
Normally that screw is alot further inward. It all comes down to how much pull that spring has on the gov arm, since the throttle blades are directly linked to that gov arm. If u watch it close while you sre working throttle u will be able to see it. Run the screw in deep until your idle starts to raise then back off just enough to idle good. |
Author: | Bayport [ Mon Nov 02, 2015 9:20 am ] |
AHHHHHHHHHHH I was adjusting the screw the wrong way. Did as u said and getting 4100 OOTW now! Thanks so much to all for the help. Maybe get to try it this afternoon.. |
Author: | Bayport [ Mon Nov 02, 2015 10:51 am ] |
Well still only getting 3 k in the water w light load by myself Running a 9x6 Getting about 18.5 mph Not bad at all but that engines power is at 33-35 Wish I could try a 9x5 without having to buy one LT |
Author: | Will C [ Mon Nov 02, 2015 11:07 am ] |
Before when u said u could get 4100 by manually opening throttle, im guessing that was out of water? Ur motor might really need a valve job or your cam may be going flat |
Author: | Will C [ Mon Nov 02, 2015 11:08 am ] |
You should pull a 9x6 prop with no problem. I wouldnt go to a 9x5, 3k at 18 mph, u must have a very light boat or a big prop, any chance this prop is really bigger but labeled 9x6, ive seen some very odd props with random writing and stamps that were not what they said , they were not go devil props |
Author: | Bayport [ Mon Nov 02, 2015 11:50 am ] |
Had valves adjusted end of last year Interesting comment about prop It is not a gd prop according gd ( was on the motor when I bought it used) Appreciate the input |
Author: | Russ [ Mon Nov 02, 2015 12:25 pm ] |
It's a 1436, will. Light boat for sure. Turn the oow rpms up to 4500. That engine won't have any issues with that. |
Author: | Bayport [ Mon Nov 02, 2015 12:34 pm ] |
Author: | Russ [ Mon Nov 02, 2015 12:43 pm ] |
I'm not messing with you. The internals and block can handle it. Cb5331 has a lot of experience with them. It'll let you turn a bit more in the water before the governor stops you. |
Author: | Bayport [ Mon Nov 02, 2015 12:48 pm ] |
I'll give it a shot. What would be the downside of going w a 9x5? |
Author: | Russ [ Mon Nov 02, 2015 1:22 pm ] |
Less top speed. For a longtail, nothing. |
Author: | Will C [ Mon Nov 02, 2015 2:16 pm ] |
I ran a 25 lt with a 9x7 on a 1636 old duracraft for years. Always ran around 4k, i ran 9x6 a couple times too.if You cant turn a 9x6 on your 1436 then goin to a 9x5 is not the fix. Just my 2c |
Author: | Will C [ Mon Nov 02, 2015 2:19 pm ] |
U got some good pics of your 9x6 by chance? |
Author: | Bayport [ Mon Nov 02, 2015 2:27 pm ] |
Just took them today for GD |
Author: | cb5331 [ Mon Nov 02, 2015 2:42 pm ] |
Yea, I'd set the governor at 45-4600..., you won't really turn that high in the water, but it will keep the gov from trying to engage too soon while your running and 45-46 is fine for the occasional blip if you hit something. It's actually fine to just run at those rpm's, but you won't. If you set it lower, like 42-4300, it starts limiting you down in the 39-4k range, so when the motor is already under load, it just won't let you get the full potential. Set a little higher, then you might be able to actually run at 42-4300 in the water. Governor is a gradual thing. Not quite the same as an electronic rev limiter. |
Author: | Bayport [ Mon Nov 02, 2015 2:50 pm ] |
Will give it a go...but seemed like the idle got too high where that screw needs to be to get 43-45 I suppose I could adjust that directly on the carb... Also, what about grinding off some of that cup? I don't run mud...,mostly weeds here in Fla. |
Author: | Will C [ Mon Nov 02, 2015 3:02 pm ] |
As they said , raise your oow rpm but since you have already raised it by 400 rpm and saw no improvement in water im goin back to prop. I cant see a smoking gun prop issue from pic. I really wish your neighbor had a prop for you to try out. That prop looks familiar. I hope you can find a clean 9x6 to try out. If you have GD on the phone anyway, order a new 9x6 |
Author: | cb5331 [ Mon Nov 02, 2015 3:29 pm ] |
I didn't read this whole post, just the last one that had my name in it... Will may be on to something with the prop.. If turning up the gov to 45-4600 pulls your idle up, you need a stronger gov spring, or need to zip tie a few links of the spring together. |
Author: | Bayport [ Mon Nov 02, 2015 3:33 pm ] |
Author: | Bayport [ Wed Nov 04, 2015 1:05 pm ] |
I ground down the cup on the prop but still no improvement in on the water RPM;s and that is w OOTW at 4300 I'm gonna borrow a 9x6 backwater prop and see if makes a difference Have to ask a dumb question....I have 1/4in fuel line from motor to ball but then 3/8 from ball to tank. Total length is only a few feet as I keep the tank in the back. Would that 3/8 fuel line cause an issue? Thx in advance LT |
Author: | Will C [ Wed Nov 04, 2015 1:12 pm ] |
Usally if you starve for fuel you really feel drop , "surging". Your sounds consistant. If its fuel related then it would prob be dirty jets. I think ur fuel ine is ok but swapping to 1/4 line is cheap anyway |
Author: | Bayport [ Wed Nov 04, 2015 1:14 pm ] |
Author: | Will C [ Wed Nov 04, 2015 1:20 pm ] |
My 1636 would shove the nose into water at 21mph no mater what prop. Your boat is even shorter so that might become a prob once motor is right. My rpm was always up around 4k. |
Author: | Bayport [ Mon Nov 09, 2015 11:18 am ] |
Well, tried w a Backwater 9x6 and it was worse..lost 250 RPM w that. Gonna contact GD and see if they would loan me a 9x5 to try |
Author: | Will C [ Mon Nov 09, 2015 10:57 pm ] |
Im glad you tried another one. If it was in my shop it would get a leakdown test and a cam inspection |
Author: | Bayport [ Tue Nov 17, 2015 1:55 pm ] |
One of the cylinders is 20# less than the other... Think I'll run it till it dies Thanks for all the help |
Author: | Will C [ Tue Nov 17, 2015 10:09 pm ] |
Thank you for the closure, now we kno its hurt . |
