It is currently Mon Apr 13, 2026 12:19 am
[ 9 posts ] |
27 mini issues please help
accura45
So motor was running fine last weekend out hunting, then on the way back to the ramp it just started having no power and I'm only getting about 2000 rpms tops. If I lift the prop out of the water it will rev up to 4100 rpms but as soon as I put prop back in water it does same thing. When lifted out of water and out of water on trailer will rev slowly to 4100 but just won't in water. I changed to new plugs (champions gapped at .030). Also new fuel in tank. Not sure what is wrong and what would happen all of a sudden like this. Also sprayed gumout carb cleaner thinking maybe it's dirty but still same problem. Any ideas please help. Used search feature but not really sure where to start. The motor has 320 hours and has had oil changed and all maintenance done as its my baby.
| Sat Nov 14, 2015 4:38 pm |
Russ
 Re: 27 mini issues please help
Air getting into the fuel line somewhere?
| Sat Nov 14, 2015 5:19 pm |
accura45
I'll look over the fuel line here quick and also how much do you guys vent your gas tanks?
| Sat Nov 14, 2015 5:38 pm |
accura45
Cut back and reclamped all fuel line connections just to be safe seems like it's a lil better hopefully will be running good in morning on water
| Sat Nov 14, 2015 8:06 pm |
jakehawk9
Joined: Wed Jul 01, 2015 6:06 pm Posts: 1447 Location: South central, ks
I just use a vented gas cap
| Sat Nov 14, 2015 8:39 pm |
Russ
I leave the vent closed and actually loosen the whole cap. Keeps water from collecting on the cap, and still lets it vent.
| Sat Nov 14, 2015 9:10 pm |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
Before you start tearing the engine or carb apart make sure you have spark on both sides. Your symptoms are classic for one dead cylinder. I would guess a coil.
_________________ so many rivers, so little time
| Sat Nov 14, 2015 9:19 pm |
deadbird8
| Sun Nov 15, 2015 6:57 am |
accura45
Are the coils pretty easy to install I'm mechanically inclined just unsure of what all is needed to change the coils
| Sun Nov 15, 2015 8:10 pm |
[ 9 posts ] |
