23hp Dixie clutch replacement? Where do you buy or find http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=64737 |
Author: | Lnlking928 [ Sat Nov 28, 2015 12:23 pm ] |
Post subject: | 23hp Dixie clutch replacement? Where do you buy or find |
I have a 23hp Dixie that the clutch went out on and I can't find any numbers on it. If anybody knows I need to find a replacement as well as a pulley that goes with the clutch ASAP |
Author: | DmaxHunter [ Sat Nov 28, 2015 2:22 pm ] |
Post subject: | Re: 23hp Dixie clutch replacement? Where do you buy or find |
Pm muxxed he re-engineered his dixie, before finally ditching it. Also, if it's a 23 briggs get pto shaft diameter, this will help narrow down watch clutch you can purchase |
Author: | Lnlking928 [ Sat Nov 28, 2015 2:38 pm ] |
The clutch I have an idea on. The pulley is what I'm in the air about how to get and if it will match up with the clutch correctly |
Author: | Lnlking928 [ Sun Nov 29, 2015 11:03 am ] |
I tried to find muxxed to pm him but couldn't find his username. |
Author: | DmaxHunter [ Sun Nov 29, 2015 11:14 am ] |
I text him the link to this thread |
Author: | Lnlking928 [ Sun Nov 29, 2015 3:26 pm ] |
Appreciate it. Hope I can get some insight on changing this clutch and busted pulley |
Author: | ktm261 [ Sun Nov 29, 2015 3:56 pm ] |
What tooth pulley do you have? I have a 34 tooth assembly. It's used but worked fine when I took it off to regear. |
Author: | Lnlking928 [ Sun Nov 29, 2015 4:03 pm ] |
I still have the stock pulley on. Think it was 36. Where did you buy a replacement? |
Author: | ktm261 [ Sun Nov 29, 2015 4:31 pm ] |
I actually took clutch off and went to direct drive. I got a Dodge taper lock and pulley. |
Author: | Lnlking928 [ Sun Nov 29, 2015 4:37 pm ] |
Yea I'm wanting to go back with the clutch. but since Dixie out of business there isnt much info available on replacement parts that will work. |
Author: | mudxxed [ Sun Nov 29, 2015 5:39 pm ] |
You can use mudbuddy clutch and upper pulleys with the Dixie. They are the same. I don't see how the pulley would be bad tho. The clutch is a magnet that engages the metal disk of the upper pulley |
Author: | Lnlking928 [ Sun Nov 29, 2015 7:37 pm ] |
Bearing went out and sheered the key And wedged it to the shaft so the pulley and clutch had to be cut off. Had hydraulic pullers and porta powers pushing it wouldn't budge so had to cut it to get it loose enough to come off. Where can you get the mud buddy replacement not for 7-800 bucks? |
Author: | mudxxed [ Sun Nov 29, 2015 8:02 pm ] |
Give Andy/Hank at boat dr a call. He should have some pulleys in stock, if not mudbuddy has some. Should run about 160 if I rexall |
