Re: 23 gdsd running lean?
the idle adjustment screws r on the top of the carb take off the airbreather cover ,3r4 screws, an under this cover there is 2 black plastic adjuster 1 on each side of carb the plastic is to limit the amount of adjustment but if u remove this plastic u can adjust these screws more only if u nedd to i would run with one plugwire off of plug at a time adjusting the srews as needed hope this helps
