smoking 35 http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=6545 |
Author: | bussterwyatt [ Mon Dec 14, 2009 12:37 pm ] |
Post subject: | smoking 35 |
put my stock air cleaner on the other day to run in the rain and in the garage when i give it the gas it puts out a puff of smoke and then clears up ? every time i goose it it will puff out some smoke .doesnt matter what rpm im in when i add the gas it will smoke and then clear up like i got a leaky valve seat and oil is getting into the combustion chamber ? dont know. new at the mud motor thing |
Author: | DMC [ Mon Dec 14, 2009 6:08 pm ] |
Post subject: | Re: smoking 35 |
It could be the valve seals or possibly the stock air cleaner is really dirty and causing the engine to pull too much of a vaccum from the valve cover breather sucking up some oil. Just a thought. Not sure what else it could be if the air cleaner is the only thing you changed. |
Author: | bussterwyatt [ Mon Dec 14, 2009 6:14 pm ] |
yea im not to concerned but thought i would throw it out there i cant remember it doing that before but the filter is new but i put the pod filter back on i pull the plugs out and check for oil |
Author: | 50fps [ Mon Dec 14, 2009 6:23 pm ] |
Does the dipstick pop up a bit after a long WOT run? |
Author: | bussterwyatt [ Tue Dec 15, 2009 12:04 pm ] |
matter of fact it does . breather ? |
Author: | coondik [ Tue Dec 15, 2009 1:45 pm ] |
if it is coming out of your air filter, chances are the problem is with your valves / seating. if there is smoke & light oil discharge coming out of your breather than most probably it's a head gasket. do a compression test and a leak down test on her & let us know what u find. btw: dipstick poppin' out could possibly signify excess base pressure. possible cause would be leaking head gasket as well! |
Author: | bussterwyatt [ Tue Dec 15, 2009 2:14 pm ] |
ok thanx coondick. this was a used motor with 20 hours on the hour meter LOL that i bought off of here. a water cooled briggs . it runs strong, i did the old news paper over the oil fill hole at idle sucked it in place so there isnt any or very little blow by. i will do a compresion test tonight and see what the leak down is |
Author: | Sparkleberry Runner [ Wed Dec 16, 2009 9:12 pm ] |
Author: | bussterwyatt [ Fri Dec 18, 2009 4:38 pm ] |
time for new rings .to much crankcase pressure |
