Honda gx270 governor spring tighten
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=66515
Author:  bc23 [ Sat Apr 09, 2016 3:26 pm ]
Post subject:  Honda gx270 governor spring tighten
I have recently purchased some mods for my boat to get a little more hp. This is my first long tail and attempt to mod my engine. I do not want to remove the governor because I was some protection for the engine. I have read that I can I tighten the governor to get some extra rpm. Can someone please can explain which and how to tighten the governor spring?
Thanks
Bc23
Author:  brycecheramie [ Sat Apr 09, 2016 4:57 pm ]
Post subject:  Re: Honda gx270 governor spring tighten
put a tie wrap on the spring to tighten the loops, and make the spring pull harder on the gov.
Or get a stiffer spring.
Author:  bc23 [ Sat Apr 09, 2016 7:20 pm ]
Author:  brycecheramie [ Sat Apr 09, 2016 7:30 pm ]
Author:  bc23 [ Sat Apr 09, 2016 8:13 pm ]
That makes sense. I am look online to see if I can find a stiffer spring.
Thanks
Bc23
Author:  brycecheramie [ Sat Apr 09, 2016 8:14 pm ]
I already took the spring off, and made the bend a little sooner.
Make sure not to bend it to much to make it shorter, because it will cause you motor to idle higher.
Author:  bc23 [ Sun Apr 10, 2016 5:22 pm ]
Thanks for your help
