It is currently Sat Apr 11, 2026 10:11 pm
Reply to topic  [ 11 posts ]
 Case Leak
Post Case Leak
37 EFI just hit 60hrs and I noticed a thin coat of oil halfway down the block. Not enough to drip or notice on the dipstick. I have all intentions to go to the Sparkelberry swamp duck run, which is next Saturday. Would it hurt or lead to any further issues by running it one more time before carrying it to the shop?
Sun May 29, 2016 4:56 am
Post Re: Case Leak
Just make sure the case bolts are torqued properly and rock on.
Sun May 29, 2016 7:34 pm
Post Re: Case Leak
Do like cb said and check your bolts. I ran mine for a year and half with it leaking worse than what you just described.
Sun May 29, 2016 9:25 pm
Post Re: Case Leak
mine been leaking for years. roll on.
Mon May 30, 2016 10:39 am
Post Re: Case Leak
If it worries you tilt it up, it real well and smear some etc on the crack
Mon May 30, 2016 2:04 pm
Post Re: Case Leak
Dang homie. Didn't believe me? :lol:
Mon May 30, 2016 2:24 pm
Post Re: Case Leak
Mon May 30, 2016 4:24 pm
Post Re: Case Leak
Mon May 30, 2016 7:10 pm
Post Re: Case Leak
With a motor that new, its under warranty for that repair, Check the 3 bolts on the oil filter side for 200" pound TQ and go enjoy your run, make an appointment with your dealer to get it fixed at your convenience.
Tue May 31, 2016 5:09 am
Post Re: Case Leak
Is this an EFi with a liquid gasket from the factory? Did some of the earlier motors still have a regular gasket? Just curious if the new way of sealing the crank case is making a difference.
1854 Prodigy DPE Level 3 HDR
Tue May 31, 2016 6:15 am
Post Re: Case Leak
all EFI's have liquid sealant.
Tue May 31, 2016 7:27 am
