It is currently Fri Apr 10, 2026 6:55 am
Reply to topic  [ 4 posts ]
 Pro-Drive Losing throttle
Post Pro-Drive Losing throttle
Okay folks hopefully you can help me out. Took the boat out today and everything ran as it always has except for the fact that when I am on the throttle and I trim the motor up or down the throttle drops off for a second or two and then comes back. It happened the entire day and I always had the issue (it wasn't sporadic). I tried searching the forums and it appears people have had issues with the rocker switches not working but I couldn't find something talking about this issue. It is a Gen III Pro-drive purchased about a year ago. Any help will be appreciated.
Sun Aug 21, 2016 9:55 pm
Post Re: Pro-Drive Losing throttle
If you have a stock carb, there is a solenoid on the carb that is used to cut off fuel when the engine is killed. If you have a wire or a possible ground issue, it could be that while running, the vibration is causing something with it, thus cutting fuel to the carb. You can actually remove that solenoid from the crab and plug it to see if that is the issue. If so, then it would be back tracing the problem wire. If the problem still persists, then it could still be a wire issue.
Mon Aug 22, 2016 4:28 am
My apologies... It's the 37 EFI...
Mon Aug 22, 2016 5:09 am
Mine did this.
Make sure your battery cable on the bottom of the starter is tight, check the plugs on the wiring harness and relays under the intake cover
I gave up mud motors
Mon Aug 22, 2016 5:39 am
