| Gatortail 37 EFI losing power on plane http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=67531 |
| Author: | ALUBOYS [ Sat Jul 16, 2016 2:57 pm ] |
| Post subject: | Gatortail 37 EFI losing power on plane |
Need some help guys. Here is the link to the video: https://youtu.be/Foq2YfEHjek |
| Author: | 50fps [ Sun Jul 17, 2016 8:53 am ] |
| Post subject: | Re: Gatortail 37 EFI losing power on plane |
That is cutting out abruptly so I'd guess there is an electrical issue or fuel pressure problem. |
| Author: | ALUBOYS [ Sun Jul 17, 2016 10:18 am ] |
Yes it is. Was thinking fuel pump or fuel pump relay. So far I have done the following. Motor losing power on plane between 2800-4200 rpm. Idles fine. So far have: 1. Hooked a new tank and fuel line with new gas 2. Changed both fuel filters 3. Bypassed kill switch 4. Checked battery connection 5. Changed air filter 6. Checked fire from both coils |
| Author: | MaXXis85 [ Mon Jul 18, 2016 5:31 am ] |
Bring it to your nearest service center for repair under warranty. |
| Author: | ALUBOYS [ Tue Jul 19, 2016 3:56 pm ] |
Fixed. Bad connection on positive terminal of cylinoid above starter. Wiggle the wire and it would cause the engine to lose power. Replace connector and she runs like a top. Hoyt at GT said they replace both of those cheap ass connectors when they build them out. |
| Author: | Will C [ Tue Jul 19, 2016 4:00 pm ] |
Good deal! Thanks for update |
| Author: | SETx Longtail [ Tue Jul 19, 2016 4:01 pm ] |
Go over all the connections. You're pretty fortunate that one didn't KO the ECM. Good find. |
