It is currently Thu Apr 09, 2026 6:29 pm
Reply to topic  [ 8 posts ]
 Gtr belt remove help
Post Gtr belt remove help
Got the gear and plate behind it moving finally, and looks like there's a few pieces about to fall apart inside it. Took the long 5/8 bolt out completely. Am I removing the gear right? Just backed off of it after I saw what was goin on. Never can be too cautious I guess, it's only 8k lol.
Tue Jul 19, 2016 9:44 pm
Post Re: Gtr belt remove help
loosen the four bolts that hold the engine to the frame and tilt the motor back to get enough slack so you can get the belt off of the bottom pulley and then I think you can handle it from there.
Wed Jul 20, 2016 5:45 am
Wed Jul 20, 2016 6:53 am
Guess I should of specified that I'm trying to get it off so I can take the motor off to mod it. Will the belt go over the friction plate? Or how do you slip it off without taking it off the bottom gear? I've tilted it back, maybe it takes 2 people to tilt and then work the belt off? Thanks for help guys
Wed Jul 20, 2016 4:38 pm
Try taking the planetary housing off.
Wed Jul 20, 2016 5:28 pm
Wed Jul 20, 2016 6:36 pm
Sorry that was the outer planetary I just described how to remove but take that off of you haven't already
Sent from denda this
Wed Jul 20, 2016 6:38 pm
Got it broke down! Thanks for the help!
Wed Jul 20, 2016 7:43 pm
