It is currently Thu Apr 09, 2026 5:24 pm
Reply to topic  [ 13 posts ]
 Battery getting drained
Post Battery getting drained
In at a loss...I've replaced the ignition, wiring harness, checked all grounds, etc. Any other ideas about what could be draining the battery?
Just throw the rubbers on the dash and take a chance
Thu Jul 28, 2016 3:33 pm
Post Re: Battery getting drained
If you can get your hands on an ammeter, you can measure the current draw. Disconnect accessories one at a time until the parasitic draw goes away. Best way i know to isolate it
Thu Jul 28, 2016 3:41 pm
Is your stator working?
Thu Jul 28, 2016 5:22 pm
1854 Prodigy DPE Level 3 HDR
Thu Jul 28, 2016 5:26 pm
Thu Jul 28, 2016 5:27 pm
Maybe i misread. Is this a parasitic drain? Dies while sitting or while running?
Thu Jul 28, 2016 5:33 pm
:lol: ^^^^^
JUST ANOTHER FARMER ON WELFARE
Thu Jul 28, 2016 5:45 pm
Maybe I misread, I guess I just assumed it wasnt charging .
Thu Jul 28, 2016 6:21 pm
Thu Jul 28, 2016 7:26 pm
Disconnect wires. If it arcs a little when you hook it back up you've found your drain.
Thu Jul 28, 2016 7:29 pm
A test light will also work if u don't have a meter. Disconnect neg battery cable hook up test light lead between m
Neg cable and neg terminal. If it is lite u will have a short. Once u isolate the draw light will not illuminate. Remember that gps and radios pull a draw take them out of the circuit. Also check regulator plug. Seen some that are burnt and can cause a problem.
Thu Jul 28, 2016 8:02 pm
Bayou Surface Drive
337-351-0362
Tarkington, TX 77327
Fri Jul 29, 2016 5:22 am
Do you have electronic shift?? If so...do you make sure your key is off? Reason I say is the vast majority of times I shut down I use the kill switch. I forget that I left the key in the on position and the switch still in forward....drained my battery 3 times now on accident doing that.
Fri Jul 29, 2016 1:19 pm
