It is currently Thu Apr 09, 2026 11:07 pm
[ 7 posts ] |
any ideas, engine seems to hydro lock when tilted down
TFL
I am a new guy here, have a 35hp stock mud buddy on a 3 man gator hide been out a couple of times with the boat since I purchased it two months ago, have had an absolute blast with it
run the motor every couple of weeks to keep things charged and running
last night I went to start it, but first I disengaged the trailering lock pin, and let the motor down went to start it and starter would make a half turn, then bounce back, tried it a couple of times and it seemed like the motor had a hydro lock on it, put the motor back up on the locking pin, after a few minutes it turned over fine and ran great
lowered it while running, and started to back fire at higher rpms.
could the oil somehow be causing a hydro lock in the engine?
when tilted down the oil level reads full, when the engine is level it reads less than full on the stick
5W30 mobile one synthetic
| Fri Jun 24, 2016 5:57 am |
Will C
 Re: any ideas, engine seems to hydro lock when tilted down
Could be the float tab is a bit out of adjustment. That will fill up a cylinder with gas. Make sure u dont have gas in the oil. Also make sur tank is vented good
| Fri Jun 24, 2016 11:35 pm |
TFL
found the problem yesterday, started it and only had one head generating heat, shut it down pulled the plug and the top of the plug was squished, some porcelain knocked off. so I stripped down the motor, took off that side head , found out in disassembly that the muffler is toast, all loose inside something must have fell inside the head and busted the plug the head inside looked good, so the piece must have exited the exhaust port. just waiting on a head gasket and will re assemble this week . need a new muffler will get a SS model lucky no scoring inside the cylinder wall, everything looked good inside.
| Tue Jul 05, 2016 6:53 am |
Will C
Glad u found it. While the head is off at least check the valves for leaks or you might put head back on for nothing.
| Tue Jul 05, 2016 10:54 am |
cb5331
You know they're leakin'
| Tue Jul 05, 2016 4:54 pm |
Will C
 leak a bit, it will fly. Leak alot or bent. At least u will have practice for the next time
| Tue Jul 05, 2016 7:24 pm |
TFL
finally had a chance to put it all back together yesterday, a slip up at the local shop had me waiting 2 weeks extra for a head gasket also put a new SS exhaust on it, new gaskets, fired it up and all seems good to go. will have to wait til the weekend to get it on the water and give it a tryout.
all in all a fun job to do
| Mon Jul 25, 2016 10:46 am |
[ 7 posts ] |
