It is currently Wed Apr 08, 2026 8:26 pm
Reply to topic  [ 17 posts ]
 23 VanGuard Carb Solenoid
Post 23 VanGuard Carb Solenoid
Can someone verify that a 2003 GoDevil VanGuard Longtail has a solenoid on the carb? I think this is why it wasn't starting for me the other day...
It's at the shop getting a leak down test but I'd like to have a game plan for getting it running again when I get it back.
Fri Jul 29, 2016 7:25 pm
Post Re: 23 VanGuard Carb Solenoid
does it have a wire going into the bottom of the bowl on the carb?
Fri Jul 29, 2016 7:29 pm
Yeah I know that will be the give away but it's at the shop. Just anxiously brainstorming and hoping that it does.
Fri Jul 29, 2016 7:34 pm
I don't believe they have one on your motor, but I could be wrong.
I searched google a bit
Fri Jul 29, 2016 7:39 pm
Not thinking it does either... Back to the drawing board. Has spark and the pump appears to be pumping fuel. Valves adjusted as well
Fri Jul 29, 2016 7:57 pm
Clogged jets In the carb?
It normally doesn't take much for these motors to run.
Air, Spark, and fuel.
Has the motor been sitting up a while?
Bad fuel?
Fri Jul 29, 2016 8:01 pm
Sat for maybe 2-3 weeks fuel isn't too old and has had sea foam in it. Cap was tight so shouldn't have water in it.
Fri Jul 29, 2016 8:05 pm
Whats it doing at the shop?
Have them fix that! :lol:
Fri Jul 29, 2016 8:06 pm
Just doing a leak down. It has fresh plugs, oil, and filters. Cleaned the carb a month or two ago but maybe need to do it again.
Fri Jul 29, 2016 8:09 pm
Can a throttle cable adjustment or governor adjustment cause this?
Fri Jul 29, 2016 8:10 pm
I wouldn't think so,
As long as you put it together the same way you took it apart!
Fri Jul 29, 2016 8:30 pm
Tilt safety switch?
Sat Jul 30, 2016 7:38 am
This week i had one that wouldnt start. I held pressure on the bulb and bounced motor up and down. I felt the bulb squeeze when the float fell down from its stuck position, fired right up
Sat Jul 30, 2016 9:12 am
Sat Jul 30, 2016 9:59 am
Will, you rebuilding valves now?
:razz:
Sat Jul 30, 2016 10:01 am
Hope your leakdown is good. For clay, i just weld up the low spots then true them back up with a 36 grit. :D
Sat Jul 30, 2016 10:42 am
No worries, they don't need to be true. Briggs sure don't think so, anyway. :lol:
Sat Jul 30, 2016 10:46 am
