| 23 VanGuard Carb Solenoid http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=67690 |
| Author: | Kheeney5 [ Fri Jul 29, 2016 7:25 pm ] |
| Post subject: | 23 VanGuard Carb Solenoid |
Can someone verify that a 2003 GoDevil VanGuard Longtail has a solenoid on the carb? I think this is why it wasn't starting for me the other day... It's at the shop getting a leak down test but I'd like to have a game plan for getting it running again when I get it back. |
| Author: | brycecheramie [ Fri Jul 29, 2016 7:29 pm ] |
| Post subject: | Re: 23 VanGuard Carb Solenoid |
does it have a wire going into the bottom of the bowl on the carb? |
| Author: | Kheeney5 [ Fri Jul 29, 2016 7:34 pm ] |
Yeah I know that will be the give away but it's at the shop. Just anxiously brainstorming and hoping that it does. |
| Author: | brycecheramie [ Fri Jul 29, 2016 7:39 pm ] |
I don't believe they have one on your motor, but I could be wrong. I searched google a bit |
| Author: | Kheeney5 [ Fri Jul 29, 2016 7:57 pm ] |
Not thinking it does either... Back to the drawing board. Has spark and the pump appears to be pumping fuel. Valves adjusted as well |
| Author: | brycecheramie [ Fri Jul 29, 2016 8:01 pm ] |
Clogged jets In the carb? It normally doesn't take much for these motors to run. Air, Spark, and fuel. Has the motor been sitting up a while? Bad fuel? |
| Author: | Kheeney5 [ Fri Jul 29, 2016 8:05 pm ] |
Sat for maybe 2-3 weeks fuel isn't too old and has had sea foam in it. Cap was tight so shouldn't have water in it. |
| Author: | brycecheramie [ Fri Jul 29, 2016 8:06 pm ] |
Whats it doing at the shop? Have them fix that! |
| Author: | Kheeney5 [ Fri Jul 29, 2016 8:09 pm ] |
Just doing a leak down. It has fresh plugs, oil, and filters. Cleaned the carb a month or two ago but maybe need to do it again. |
| Author: | Kheeney5 [ Fri Jul 29, 2016 8:10 pm ] |
Can a throttle cable adjustment or governor adjustment cause this? |
| Author: | brycecheramie [ Fri Jul 29, 2016 8:30 pm ] |
I wouldn't think so, As long as you put it together the same way you took it apart! |
| Author: | 50fps [ Sat Jul 30, 2016 7:38 am ] |
Tilt safety switch? |
| Author: | Will C [ Sat Jul 30, 2016 9:12 am ] |
This week i had one that wouldnt start. I held pressure on the bulb and bounced motor up and down. I felt the bulb squeeze when the float fell down from its stuck position, fired right up |
| Author: | Kheeney5 [ Sat Jul 30, 2016 9:59 am ] |
| Author: | cb5331 [ Sat Jul 30, 2016 10:01 am ] |
Will, you rebuilding valves now? |
| Author: | Will C [ Sat Jul 30, 2016 10:42 am ] |
Hope your leakdown is good. For clay, i just weld up the low spots then true them back up with a 36 grit. |
| Author: | cb5331 [ Sat Jul 30, 2016 10:46 am ] |
No worries, they don't need to be true. Briggs sure don't think so, anyway. |
