It is currently Wed Apr 08, 2026 9:51 pm
Reply to topic  [ 23 posts ]
 Cam - will this work
Post Cam - will this work
My heart sank as I'm about to install the cam, and I notice this little baby chip. Will this work or am I screwed? Not happy but not Gona bash the dude, because I don't think this was intentional. But I know it wasn't on my part because its been sittin in the bubble wrap until now.... Man...
Thu Jul 28, 2016 7:39 pm
Post Re: Cam - will this work
Put on a true straight edge and make sure the chipped area is all negative compared to thrust flange surface .If so then polish that area with 400/600 paper to make sure you wont eat the block . I wouldnt like it but i might run it .
Thu Jul 28, 2016 7:50 pm
I would look real close for any other "drop" marks. Used cams are a gamble anyway
Thu Jul 28, 2016 7:54 pm
I know man. Got me bent out of shape. Thought about ordering a new one. Being that the whole cylinder is there besides that small chip, I wouldn't think it would hurt anything, and would stay true to shape while spinning, but I had to ask people with some experience on this.
Thu Jul 28, 2016 8:01 pm
I would not use it.
Thu Jul 28, 2016 8:07 pm
I wouldn't run it but it should be a simple repair for any camshaft shop.
-Custom pool noodle
-stage 4 water wings
Thu Jul 28, 2016 8:11 pm
Agreed. Wouldn't run it, but it's fixable, and won't cost much.
Now, a rolled lobe is a different story, but I won't jack your thread up anymore with that entertaining tale.....
Thu Jul 28, 2016 8:43 pm
Anybody had luck with the billet cams? I might just buy another one. I've always been told Pvts were decent so I wanted to try it. What kind of cams have y'all had good luck with? Somebody said to go with a Nick Peltier 308.
Thu Jul 28, 2016 10:22 pm
keep that out of your engine with it like that. Id be getting a refund.
Fri Jul 29, 2016 4:24 am
Fri Jul 29, 2016 5:19 am
Thanks for the info. I'm sure it would eat it up quick and get into the block, causing problems. Tried to find info on the different grinds with little luck. In your opinion should one go with 310, or 312, instead? What's the difference in performance vs 308? I have the pink springs and shims .060, so I don't want to change that. What can I run without having to do different shims.
Fri Jul 29, 2016 8:58 am
How heavy is your boat, what exhaust, what valves in heads, flat face or dish. Intake port matched? List all info u can and these guys can point u in right direction
Fri Jul 29, 2016 10:29 am
Boat is fairly heavy 17.6 X 50 gator trax. Stock gutted, and stock sized Manley valves is what he's installing.
Fri Jul 29, 2016 10:36 am
Imo i wouldnt go any bigger than 308 wich is usally bout 246@.050. Going bigger could make your engine soggy on the bottom end and have peak power above the rpm you are goin to run anyway
Fri Jul 29, 2016 1:21 pm
Thanks for the tips Will!
Fri Jul 29, 2016 8:29 pm
That cam lobe looks pretty worn also
Sat Jul 30, 2016 8:47 pm
Yea kinda unfortunate how much You can get screwed online for parts. Learned that the hard way to just buy new. Not telling people what to do with their $, but I'd definitely do some checking before buying parts. Especially on mud motor central. It don't matter if they've only put (or claimed to of put) very few hours on the parts, if they are damaged. At least now I know what to look for since I've started building one on my own. Think I'll give Pvt or dyno cams a call soon for another 308.
Sun Jul 31, 2016 12:10 am
Mon Aug 01, 2016 6:20 am
Are u saying he should go bigger than 308?
Mon Aug 01, 2016 7:35 am
I wouldn't run it in my motor. I see your options as these. Bring it in and have it welded, machined, OD ground and install it, or get a new one.
1854 Prodigy Open
HDR/Stage 3 mods
Prodigy Boats Pro Staff
BPS Swamp Staff Member
Blackwater Marine LLC.
Mon Aug 01, 2016 7:38 am
Mon Aug 01, 2016 9:15 am
10 4, we are the same page. I just didnt think he has enought compression to run a "bottom of the page cam". For the record im not saying just grab a 308, just saying i wouldnt go bigger on his rig
Mon Aug 01, 2016 10:22 am
Mon Aug 01, 2016 10:40 am
