It is currently Tue Apr 07, 2026 1:19 am
[ 7 posts ] |
slingshot
 Stalling problem.
So I was running the boat the other day , short run around 10 / 12 miles or so , and about half way my motor just dies. I thought WTF! But after a few mins it started right back up and ran great like it all ways does. Go to my area that I wanted to fish stopped fished a bit, motor started back up no problem did this all day. When I started back to the ramp after about a few miles It dies again , this time It wont start back up. After about an hour It started up no problem ran great until til I got close to the ramp dies again. This isn't acking like a carb problem, seems like and electrical problem so when I got home I checked my kill switch and this is what Ive found, so correct me if im wrong I pulled one side of my kill switch wire on the back side of it and the motor still runs, Ive did this on both wire and the motor still runs, I pulled both wire and the motor still runs. Is this right or wrong. Also thinking reve limiter , You guys have any info to help me out? The motor is a 06 35 van guard.
_________________ 1542 stuck to a 27mini. She gone. 1746 with a modded 35 gdsd Capt Team total asalt
| Sun Aug 07, 2016 11:28 am |
slingshot
 Re: Stalling problem.
Thanks for help , Figured it out myself.
| Sun Aug 07, 2016 2:40 pm |
Rooterpig
Joined: Sat May 19, 2012 6:48 am Posts: 125 Location: East central Florida.
What was it?
| Sun Aug 07, 2016 4:31 pm |
brycecheramie
| Sun Aug 07, 2016 5:26 pm |
slingshot
Reve limiter.
| Sun Aug 07, 2016 5:56 pm |
brycecheramie
What all did you do to find that out? What exactly was wrong with the rev limiter??
| Sun Aug 07, 2016 6:17 pm |
slingshot
Well I'm not sure what's wrong with the Reve limiter but , I cut the green wire and put butt connecters on it to see if it would happen. So I started the motor and after a few mins its would dies. so I disconnected the green wire and the motor started right up and run great. While it was running I reconnected the green wire and my motor died again , so I can only assume that's the problem. With the wire disconnected the motor would run along time. While it was running I reconnected the wire back one more time, this time the motor didn't die and I thought I was back to square one , but after a few more mins it dies again. Just need to order a new one , just need to figure out where to get one.
| Sun Aug 07, 2016 7:19 pm |
[ 7 posts ] |
