| Synthetic vs. Conventional oil in 23 Copperhead http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=67783 |
| Author: | mike3503 [ Sun Aug 07, 2016 8:43 am ] |
| Post subject: | Synthetic vs. Conventional oil in 23 Copperhead |
What are the benefits of running synthetic in a 23 Copperhead? Just hit 11 hrs, and due for my first oil change, and I was going to start running synthetic, but not sure of the benefits. Also, any brand preferences? |
| Author: | Russ [ Sun Aug 07, 2016 8:48 am ] |
| Post subject: | Re: Synthetic vs. Conventional oil in 23 Copperhead |
*grabs popcorn* This is gonna be entertaining. Btw, before it begins, please search the forum so you're prepared for what's coming. |
| Author: | mike3503 [ Sun Aug 07, 2016 9:02 am ] |
| Author: | mike3503 [ Sun Aug 07, 2016 9:20 am ] |
| Author: | Russ [ Sun Aug 07, 2016 9:22 am ] |
It's not dumb, but it's not exactly something to ask. It's truly personal preference. Go read the "which oil to use" posts on here, laugh, and you'll understand. Oil in a lawnmower engine is so much more about personal preference (though some people think they're oil experts when that list is actually VERY small), and less about the mechanical advantages and disadvantages that you're about to get trolled. Just run what the owners manual says, or switch, and don't overthink it. Lol |
| Author: | mike3503 [ Sun Aug 07, 2016 9:40 am ] |
Well my lawn mower gets regular cheap oil. My mud motor gets worked a whole lot harder, at higher RPMs, and under a heavier load. The Briggs owners manual gives you the recommendations for a lawn mower application. It tells me to change the oil every 100 hrs, which I don't know anyone that changes their oil in their mud motor every 100hrs. What I'm asking, are the benefits in the application of mud motors worth the cost? May be a toss in the bucket for some, but keep in mind I'm a broke fireman, and I've gotta cut corners where I can. As in if spending the extra $$ on synthetic oil is gonna save me from costly repairs later on down the road, then I'm in. |
| Author: | Russ [ Sun Aug 07, 2016 9:44 am ] |
It probably won't. Change it more often than the owners manual states to account for the faster breakdown, typically most of us do 25-50 hours. But I run conventional. |
| Author: | Russ [ Sun Aug 07, 2016 9:45 am ] |
Btw, 23 briggs. Frame is irrelevant to your question |
| Author: | JLACOUR [ Sun Aug 07, 2016 10:20 am ] |
Since your copperhead doesn't have reverse, I'd recommend conventional. But for the guys that have reverse, they are better off with synthetic since their rotating assembly spins in both directions. |
| Author: | Russ [ Sun Aug 07, 2016 10:35 am ] |
^ X 100 |
| Author: | cb5331 [ Sun Aug 07, 2016 10:36 am ] |
Lol |
| Author: | mike3503 [ Sun Aug 07, 2016 11:15 am ] |
| Author: | dead animal [ Sun Aug 07, 2016 12:53 pm ] |
put mobil 1 10w30 in it and change it every 100 hours or until the oil turns black. got almost 3800 hrs on current briggs, and not many people on here run as hard as I do. hadn't had a oil related problem. |
| Author: | ff154 [ Sun Aug 07, 2016 8:28 pm ] |
Rotella 15-40 Change the oil and filter when it needs it |
| Author: | SETx Longtail [ Sun Aug 07, 2016 8:35 pm ] |
Rotella 15/40 and Wix filters every 20-25hrs |
| Author: | brycecheramie [ Sun Aug 07, 2016 8:41 pm ] |
Another one for Rotella. Ive had it in my mower since day one, and ive got 300 hrs on it so far, and haven't had a single issue. Also change it every 50 hours, and lots of the times, the oil isn't black. A little darker that when I put it in. |
| Author: | ibfishinb [ Mon Aug 08, 2016 5:12 am ] |
I use amsoil high zinc content synthetic. I change it every 25 hours. Sent from my SM-G920V using Tapatalk |
| Author: | ibfishinb [ Mon Aug 08, 2016 5:13 am ] |
The used oil usually looks the same as the day I put it in. Then i recycle it through my lawnmower . Sent from my SM-G920V using Tapatalk |
