It is currently Sat Apr 04, 2026 4:00 am
Reply to topic  [ 25 posts ]
 PD trim switch
Post PD trim switch
I'm having problems with my friggin trim switches. I've only been having the boat for a year and im on my 3rd one. Warrenty is about to go out and was wondering if anybody has tried any other type of switch. Thanks yall.
Thu Oct 03, 2013 5:14 am
Post Re: PD trim switch
Take all that crap off and put on a winch solenoid. You can convert everything for less money than one PD trim switch.
Thu Oct 03, 2013 5:24 am
Thu Oct 03, 2013 5:26 am
Here's a solenoid.
http://www.amazon.com/gp/product/B004VA ... UTF8&psc=1
And the switch, but there are many options on switches. this one is ready to go and has the spades that fit said solenoid.
http://www.amazon.com/ATV-Rocker-Switch ... auto_img_y
Run power straight from the battery to the solenoid and you can get the power for the switch off the starter.
Thu Oct 03, 2013 5:29 am
http://www.colehersee.com/home/item/cat/198/24452/
I was told to order this one so I ordered two one for each motor. I am tired of relays popping.
Uncle J's Custom Bow Fishing Rig 20/72 30" Sides, Calens Modded Dual GTR's
Boat Name: The Gar Barge
Team Name: Southern Stickers
18/58 Uncle J Custom 3/16 bottom 24" sides w/catwalks 6' front deck with another GTR Pushing it.
17/54 Gator Trax 35 Mud Buddy W/All aluminum FPR Mod SOLD
Thu Oct 03, 2013 6:07 am
Also would like to know how many amps the new parker trims draw cause I need to figure out if I can stay with the 12 gauge wire I have or will I need to up it to 10 gauge for a 7-8' run since I am moving the new relays to inside the boat.
Thu Oct 03, 2013 6:12 am
I ran 10awg and my longest wire is only 3', not sure about the new parker trim but I checked mine. For the most part it would be around 65 amps on average but after using it repeatedly and putting a bind on it I saw it jump as high as 144 amps. The solenoid I'm using now will take up to 175 amps for 5 seconds. The trim and reverse works much better, faster and smoother and I've had zero issues with it. The old style switches were a constant PITA and with the heavy resistance when they started acting up would make everything slow.
Thu Oct 03, 2013 6:31 am
Thanks Will, ill definately give it a try!
Thu Oct 03, 2013 6:48 am
Thu Oct 03, 2013 8:42 am
Yep, it doesn't happen all of the time but only takes once to fry a relay. :lol:
Thu Oct 03, 2013 8:47 am
Thu Oct 03, 2013 8:49 am
Will do you see anything wrong with the one I posted besides cost think they were like 50.00 each.
Thu Oct 03, 2013 9:28 am
Thu Oct 03, 2013 10:13 am
Actually I just found a cheaper price on the Trombetta reversing solenoid, looks like they're around $60 each for that brand...
http://www.amazon.com/Trombetta-Reversi ... B007W2NBTQ
http://www.trombetta.com/cm/pdfs/D03508RevD.pdf
Thu Oct 03, 2013 10:19 am
Didn't I read somewhere (can't find on here) that someone wired this up without any problems on a 3-wire setup.
Thu Oct 03, 2013 11:10 am
Thu Oct 03, 2013 11:27 am
Anyone have pictures of where they mounted the solenoid?
Fri Oct 04, 2013 12:47 pm
Put mine in the transom. Then you can put the wires in the flex conduit or box it in or put caps on the studs...
Sat Oct 05, 2013 6:57 am
Sat Oct 05, 2013 10:34 am
1848 ProDrive X Series w/ 36 PD
Tue Nov 19, 2013 2:02 pm
Tue Nov 19, 2013 2:55 pm
Appreciate the photos and ideas on the PD trim switch, and I think will be doing the same re-wire on mine. How do you protect the relay from water once its installed on the transom?
Thanks,
Wed Aug 05, 2015 7:05 pm
You don't, there sealed. I used dielectric grease on the terminals to protect them, but as far as the internals, your good.
Thu Aug 06, 2015 4:54 am
Good deal, thank you.
Thu Aug 06, 2015 2:57 pm
Finally getting around to this...you mention the switch has power from the starter. Is this the ignition starter to the switch?
Thanx
Sat Aug 20, 2016 4:58 pm
