It is currently Fri Apr 03, 2026 5:07 pm
[ 8 posts ] |
drakedog2012
 Motor cutting out
Ok guys I need some help from the masters on here I have a 4000 mudbuddy when I idle around or give it a little gas it's fine but when I go to get on to plane and give it throttle it cuts out and dies what's causing this and thanks for any help
_________________ 36 pd pushing a aircraft carrier
| Tue Aug 16, 2016 8:36 am |
ibfishinb
 Re: Motor cutting out
If you pump the primer bulb, when it is cutting out, will it pick up and go again?
| Tue Aug 16, 2016 10:18 am |
drakedog2012
No it just dies
| Tue Aug 16, 2016 10:22 am |
drakedog2012
Bulb hold pressure
| Tue Aug 16, 2016 10:26 am |
drakedog2012
Bump
| Thu Aug 18, 2016 8:03 pm |
Russ
Dirty carb.
| Thu Aug 18, 2016 8:07 pm |
Russ
I don't have that problem currently on my briggs, but we've got a 4 wheeler that does it regularly. Water in the carb, trash in the jets, etc.
| Thu Aug 18, 2016 8:10 pm |
drakedog2012
Ok thanks
| Thu Aug 18, 2016 10:00 pm |
[ 8 posts ] |
