| 37 EFI HDR http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=67942 |
| Author: | SaltyHunterF86 [ Fri Aug 19, 2016 8:37 am ] |
| Post subject: | 37 EFI HDR |
Got almost 5 hours on my motor. Went out to the shop lastnight and went to start it for a buddy to look at and I turned the key over and it wouldn't start? So I tried it again and nothing. The starter turns over but it won't start. Then I tried squeezing the throttle and it fired right up after about 10 seconds. Never have had any issues with it starting. Got a forward mounted 12 gallon gas tank. The fuel pump that came with it seemed to be working. Anybody got any idea what's going on? |
| Author: | JD145 [ Fri Aug 19, 2016 8:48 am ] |
| Post subject: | Re: 37 EFI HDR |
Probably a wiring issue. |
| Author: | SaltyHunterF86 [ Fri Aug 19, 2016 10:08 am ] |
Any ideas on the best one time fix? I heard delta is selling their bulletproof wiring harness with their efi builds. |
| Author: | Delta Performance [ Sat Aug 20, 2016 2:23 pm ] |
It is nothing that we are selling. E have found the culprit to the problem that is causing 90% of the EFI problems and fixing them the correct way Sent from my iPhone using Tapatalk |
| Author: | Roostertail3 [ Sat Aug 20, 2016 3:13 pm ] |
Delta, What is the turn around time on that fix? Thanks |
| Author: | Delta Performance [ Sun Aug 21, 2016 11:59 am ] |
If you call a schedule an appointment, it takes about an hour. Can do it while your here, or if someone wants to just drop off it is a couple days wait. Sent from my iPhone using Tapatalk |
| Author: | SaltyHunterF86 [ Sun Aug 21, 2016 5:13 pm ] |
Pm sent Delta... |
