It is currently Fri Apr 10, 2026 2:42 am
Reply to topic  [ 7 posts ]
 37 EFI HDR
Post 37 EFI HDR
Got almost 5 hours on my motor. Went out to the shop lastnight and went to start it for a buddy to look at and I turned the key over and it wouldn't start? So I tried it again and nothing. The starter turns over but it won't start. Then I tried squeezing the throttle and it fired right up after about 10 seconds. Never have had any issues with it starting. Got a forward mounted 12 gallon gas tank. The fuel pump that came with it seemed to be working. Anybody got any idea what's going on?
'97 1648LDV War Eagle '17 37EFI HDR
Fri Aug 19, 2016 8:37 am
Post Re: 37 EFI HDR
Probably a wiring issue.
1854 Prodigy DPE Level 3 HDR
Fri Aug 19, 2016 8:48 am
Post Re: 37 EFI HDR
Any ideas on the best one time fix? I heard delta is selling their bulletproof wiring harness with their efi builds.
Fri Aug 19, 2016 10:08 am
Post Re: 37 EFI HDR
It is nothing that we are selling. E have found the culprit to the problem that is causing 90% of the EFI problems and fixing them the correct way
Sat Aug 20, 2016 2:23 pm
Post Re: 37 EFI HDR
Delta, What is the turn around time on that fix? Thanks
Sat Aug 20, 2016 3:13 pm
Post 37 EFI HDR
If you call a schedule an appointment, it takes about an hour. Can do it while your here, or if someone wants to just drop off it is a couple days wait.
Sun Aug 21, 2016 11:59 am
Post Re: 37 EFI HDR
Pm sent Delta...
Sun Aug 21, 2016 5:13 pm
