It is currently Wed Apr 08, 2026 1:43 am
[ 7 posts ] |
SaltyHunterF86
Joined: Thu Jul 31, 2014 6:43 pm Posts: 64 Location: Western Kentucky
 37 EFI HDR
Got almost 5 hours on my motor. Went out to the shop lastnight and went to start it for a buddy to look at and I turned the key over and it wouldn't start? So I tried it again and nothing. The starter turns over but it won't start. Then I tried squeezing the throttle and it fired right up after about 10 seconds. Never have had any issues with it starting. Got a forward mounted 12 gallon gas tank. The fuel pump that came with it seemed to be working. Anybody got any idea what's going on?
_________________ '97 1648LDV War Eagle '17 37EFI HDR
| Fri Aug 19, 2016 8:37 am |
JD145
Joined: Wed Jun 04, 2014 9:01 pm Posts: 1289 Location: SWGA
 Re: 37 EFI HDR
Probably a wiring issue.
_________________ 1854 Prodigy DPE Level 3 HDR
| Fri Aug 19, 2016 8:48 am |
SaltyHunterF86
 Re: 37 EFI HDR
Any ideas on the best one time fix? I heard delta is selling their bulletproof wiring harness with their efi builds.
| Fri Aug 19, 2016 10:08 am |
Delta Performance
 Re: 37 EFI HDR
It is nothing that we are selling. E have found the culprit to the problem that is causing 90% of the EFI problems and fixing them the correct way
| Sat Aug 20, 2016 2:23 pm |
Roostertail3
Joined: Sun May 22, 2016 10:32 am Posts: 334 Location: Middle ga
 Re: 37 EFI HDR
Delta, What is the turn around time on that fix? Thanks
| Sat Aug 20, 2016 3:13 pm |
Delta Performance
 37 EFI HDR
If you call a schedule an appointment, it takes about an hour. Can do it while your here, or if someone wants to just drop off it is a couple days wait.
| Sun Aug 21, 2016 11:59 am |
SaltyHunterF86
 Re: 37 EFI HDR
Pm sent Delta...
| Sun Aug 21, 2016 5:13 pm |
[ 7 posts ] |
