It is currently Tue Apr 07, 2026 7:26 am
[ 4 posts ] |
jeremy
 crossover exhaust help
Im having issues with the baffle rattling loose. It has oglonged the hole where the bolt goes through and I cant get it tight enough. Has anybody ever welded it on there? Thanks
| Wed Aug 24, 2016 7:01 am |
reharbert
Joined: Tue Mar 17, 2015 1:38 am Posts: 606 Location: Beaumont, Texas
 Re: crossover exhaust help
You can't put some man hands on it and wrench it tight? You may have to replace the bolt with a new one if the threads are stretched or damaged.
If that doesn't work, put a new bolt anyways. Put a tack or two on the baffle to keep it from rattling so that you can grind it off if you ever need to remove it.
_________________ Uncle J - 17 x 48 w/GTR | Bayou Surface Drive heads | Voodoo exhaust | DIY Mikuni carb
| Wed Aug 24, 2016 8:33 am |
jeremy
Thanks for the reply The man hands broke the new bolt before it got tight. Why would I need to remove it.
| Wed Aug 24, 2016 8:52 am |
reharbert
Clean out carbon build up? Even though its SS, it could deteriorate
| Wed Aug 24, 2016 9:11 am |
[ 4 posts ] |
