| 37 wiring pic of failed wire http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=68002 |
| Author: | Will C [ Thu Aug 25, 2016 12:19 am ] |
| Post subject: | 37 wiring pic of failed wire |
I thought I would share this one and ask if anyone has any other pics of where the harness fails. This small open it the wire was on the ground wire of the main pump 1" north of the connector. The insulation looked good and you couldn't tell by looking at it. |
| Author: | Roostertail3 [ Thu Aug 25, 2016 5:43 am ] |
| Post subject: | Re: 37 wiring pic of failed wire |
How many hours on your EFI? Thanks for the post |
| Author: | Will C [ Thu Aug 25, 2016 8:07 am ] |
30 hrs on this one |
| Author: | wade_660 [ Thu Aug 25, 2016 8:34 am ] |
Was it causing any problems or you just noticed it damaged? Sent from my iPhone using Tapatalk |
| Author: | Will [ Thu Aug 25, 2016 8:36 am ] |
How about that hairline crack in the oil filler neck |
| Author: | Will C [ Thu Aug 25, 2016 8:41 am ] |
This one died on the water. Owner was towed in late in the night. The "crack" was casting flash but did look like a crack |
| Author: | cb5331 [ Thu Aug 25, 2016 8:43 am ] |
Junk |
| Author: | Will C [ Thu Aug 25, 2016 8:45 am ] |
In the pic that does look like a good crack. Can't get away with anything on here |
| Author: | cb5331 [ Thu Aug 25, 2016 8:51 am ] |
So they just use really shitty wire that's probably also too small? Is it that bull shit that pretty much crumbles if you twist it or try to crimp it? |
| Author: | Will C [ Thu Aug 25, 2016 9:12 am ] |
It seems like ok wire but the smallest wire I've ever seen to run a f pump |
| Author: | MaXXis85 [ Thu Aug 25, 2016 10:44 am ] |
| Author: | waterfowler9 [ Thu Aug 25, 2016 3:59 pm ] |
that wire looks like it was nicked by a knife or another sharp object or pulled through against a rough edge. |
| Author: | cb5331 [ Thu Aug 25, 2016 4:04 pm ] |
I think will cut it open to find the break. It was broken inside the sheathing. |
| Author: | BERNIE255 [ Thu Aug 25, 2016 4:17 pm ] |
Zip tie dat Sent from my iPhone using Tapatalk |
