It is currently Sat Apr 11, 2026 10:10 am
Reply to topic  [ 17 posts ]
 Will 37 EFI push a 4 man Gatorhide
Post Will 37 EFI push a 4 man Gatorhide
So I have the 4 man gatortrax Gatorhide with a MB Black Death 4400. Want to go with a model that has reverse. While making that change I would love the consistency of EFI but I do not have a reference for how well it will push the 20' hide. Can anyone advise if the power will be enough or should I stick with the BD line?
Fri Sep 09, 2016 4:41 pm
Post Re: Will 37 EFI push a 4 man Gatorhide
For kind of a reference, I just put a 37 on my 06 mudbuddy outdrive on a 1648 GDSD boat and with me and my buddy combined at 330# and light teal hunting load, I was getting right at 30. I don't know how much this helps.
GD 1648 SD W/37 EFI MBHD
Sun Sep 11, 2016 7:16 pm
For reference I have 36 pro drive with 1854 - loaded it down the max this weekend with 4 guys and a extra 200lbs. We were cruising at about 20mph with about 1000lbs not including boat.
Sun Sep 11, 2016 7:35 pm
It's been posted here a couple of times that a 37 Efi will run about the same as a BD 44. I have no personal experience with the 37 but that was most said here. Use the search functions you should be able to find several discussions about this exact topic.
2014 Pro Drive Gen 3
2014 17x54 X-Series
Sun Sep 11, 2016 8:25 pm
i have the 3M Hide with an MB (heads, cam and carb). she'll push 28 easy with 3 people and our hunting gear.
a stock 37 will not have the ass to push that boat at a speed you'll like during the season.
GatorHide - MB
Mon Sep 12, 2016 10:06 am
I have a new 37 if you put the vodoo on it you will gain 4 hp and not void warranty so your really not losing anything
Mon Sep 12, 2016 11:07 am
GatorHide - MB
Mon Sep 12, 2016 2:56 pm
Refurbishing a Prodrive
Mon Sep 12, 2016 4:42 pm
And your hearing
Sent from my SAMSUNG-SM-G925A using Tapatalk
Mon Sep 12, 2016 4:48 pm
:D just get the 37 and bring it to delta peformance to get level 3, youll see the speeds you want
Delta lvl 3 GTR with MAC
16x54 Gator hull
Tue Sep 13, 2016 9:40 am
It will push it. Lots of "you won't like it" from the opinions above, but ultimately you haven't stated what you're looking for with speed. Figure on (with the weight of that boat) top speed being around 26 light, down to maybe 20 or so with a 4 man hunt load. That 20 or so will take a min, just due to having to get the weight on plane. This is based off all the comparisons everyone here has made of a stock 37 efi to a stage 1, then estimated on that particular boat (which I have been in a carb, exhaust, .020 headwork on the big hide). I'm not exact with that because of all the variables (props and weight), but that should get you pretty close to an idea of what it'll do.
Tue Sep 13, 2016 11:32 am
Buddy has a 4 man hide with a 4400 HDR and runs 28. And it's a damn barge. Loaded down it still runs good.
Tue Sep 20, 2016 8:02 am
Thanks everyone! I really don't care as much about getting up to 30mph as I do about the boat getting up on plane quickly.
Wed Sep 21, 2016 2:52 pm
Wed Sep 21, 2016 2:54 pm
You could always change the prop to get the performance right or go get a gatortail 37 efi and be done with it! :lol:
Proping the motor to match the load and boat helps a lot!
Fri Sep 23, 2016 9:54 am
Fri Sep 23, 2016 10:06 am
you know the gtail bandwagon guys can't help it. gotta let the world know how great their outdated system is.
the other thingis that you will likely need a modded motor to turn a larger prop. most stock motor can't turn a hammer type prop
GatorHide - MB
Fri Sep 23, 2016 6:03 pm
