It is currently Sun Apr 05, 2026 7:50 pm
Reply to topic  [ 10 posts ]
 Delta performance packages milder than level 3?
Post Delta performance packages milder than level 3?
Just curious as to whether Delta offers a performance package that is more mild than the level 3? 3k is a lot for a motor upgrade no matter which way you swing it. Maybe just heads, valves, rods, rockers, exhaust, and tuner? That would be a nice little package an give some nice performance, could go in an add cam later if you wanted more. Would be nice to have something around a grand if you already had a decent exhaust.
PD 1754 X Series and a PD 37EFI
Thu Sep 15, 2016 8:50 am
Post Re: Delta performance packages milder than level 3?
Well heads and exhaust alone would put you well over a grand.
Not sure if the offer it but you can buy everything separate.
Sent from my beeper
Thu Sep 15, 2016 9:43 am
I have an exhaust, should have mentioned that. Heads, rockers, rods, and tuner then?
Thu Sep 15, 2016 9:58 am
Why go rods? Why not heads and efi tune, and cam? That'll be far more useful as a complete recipe than not having a cam to improve fuel/air characteristics with the valve timing. The flow improvement from the headwork will be better realized by getting the cam. Going with rods increases compression, which can be done with headwork. Doing both adds cost, but doesn't gain anything that can't be done with only headwork. Since you need the port work and should do the heads anyway, skip the rods.
Thu Sep 15, 2016 10:37 am
Not connector rods, just pushrods I meant.
Thu Sep 15, 2016 10:58 am
I think he is meaning push rods?/////// nevermind
They have a level 2, tune, heads, exhaust.
Thu Sep 15, 2016 11:31 am
Thu Sep 15, 2016 2:48 pm
I have the level 3
Thu Sep 15, 2016 4:58 pm
I guess level 1 is just an O2 sensor. Hehehe
Thu Sep 15, 2016 6:25 pm
