It is currently Sat Sep 05, 2026 1:51 pm
[ 7 posts ] |
RedRiverhunter
 Mikuni problem
I have a 2014 gtr and I took it out last weekend and when it was trimmed down it would die and I would trim up and be able to drive when I got home I took carb off and cleaned it but the air filter was full of oil it was coming from the hose from the motor. Does anyone know why this is happening
| Sat Sep 17, 2016 9:56 am |
ajridgedell
 Re: Mikuni problem
make sure its not over full of oil, or have gas in the oil from needle leaking fuel into engine.
| Sat Sep 17, 2016 9:59 am |
Will C
 Re: Mikuni problem
As he said^^ then start thinking about poss head gasket
| Sat Sep 17, 2016 12:21 pm |
RedRiverhunter
 Re: Mikuni problem
I'm good on oil it's coming from the box on the side of the motor and going straight to the air filter I know a little about motors but this got me.
| Sun Sep 18, 2016 8:07 pm |
270Handiman
Joined: Thu Dec 29, 2011 10:46 pm Posts: 2342 Location: Mandeville, LA
 Re: Mikuni problem
The 'box on the side of the motor' is the breather.
Sent from my SAMSUNG-SGH-I537 using Tapatalk
| Sun Sep 18, 2016 9:35 pm |
Will C
 Re: Mikuni problem
This usually means you have "blowby" or excessive pressure in crankcase. Usuall causes are head gasket leaking into lifter valley , piston rings not sealing , or valve seals. Most likely would be headgasket. If you say where your from someone on here can point you to someone to get it checked out.
| Sun Sep 18, 2016 9:57 pm |
RedRiverhunter
 Re: Mikuni problem
I'm in denham springs if anyone knows anybody around me just don't want it to be gone for too long since I deer hunt out of my boat also
| Mon Sep 19, 2016 5:51 am |
[ 7 posts ] |
