JphIII
 Hooks/dings in hull affect ability to reach peak RPM's?
How much would some dings in hull affect the ability to get peak RPM's out of a 37efi? Still trying to figure out whats going on with this motor and just want to eliminate any possible issues. Thing is I had a gen III PD on it previously that ran 4450 all day no issues, so I wouldn't think a dinged up hull would have that big of an impact on rpms.
_________________ PD 1754 X Series and a PD 37EFI
| Tue Sep 20, 2016 12:08 pm |
flint87
 Re: Hooks/dings in hull affect ability to reach peak RPM's?
| Tue Sep 20, 2016 12:23 pm |
JphIII
Really? 3-400 rpms? How bad are we talking here?
| Tue Sep 20, 2016 1:08 pm |
Will C
A messed up bottom can really effect performance. Keep in mind your Pd was a gen 3 with low gearing. Can't compare to your new motor
| Tue Sep 20, 2016 1:25 pm |
MaXXis85
I still belive a stock PD with 1.5 gearing should see about 4k. GTR's with 1.26 gearing are spinning 4250 with EFI's
| Tue Sep 20, 2016 1:30 pm |
JphIII
Stock PD gen IV with 1.52 gearing should do 4250+ according to KP.
| Tue Sep 20, 2016 1:43 pm |
flint87
| Tue Sep 20, 2016 3:17 pm |
kirk
Joined: Thu Apr 18, 2013 5:52 pm Posts: 870 Location: SW LA
I'm gonna try and take pics while I'm running this weekend of the water as it comes out from under the transom. It almost looks like I'm dragging something causing water to spray everywhere. I've watched other boats in person and on video and as the water travels from the bottom of the boat to the lower unit or prop , it is definitely a lot more smoother looking id say, or undisturbed. I'll try and post pics this weekend, I know good and well it's robbing my speed because I have a very light boat and poor speeds I think.
| Tue Sep 20, 2016 7:39 pm |
JphIII
I've been trying to find someone that can help patch up the bottom of my boat just to eliminate any issues there and haven't had any luck. A PITA in Raleigh, NC.... ha
| Wed Sep 21, 2016 7:26 am |
kirk
What flint did gave me enough reason to attempt it too
| Wed Sep 21, 2016 12:51 pm |
cb5331
| Wed Sep 21, 2016 1:19 pm |
kirk
| Wed Sep 21, 2016 3:22 pm |
dead animal
1.pull off your sub floor. 2. put hull on concrete slab that is flat and level. 3. get a 4x4 2 or 3' long and a 10# sledgehammer and flatten out all the hooks.
go about your bidness.
it will eventually hook again, but it will run good for a while. in the meantime save up for a well made boat. lol
good luck
| Wed Sep 21, 2016 9:38 pm |
CypressCritter
Joined: Tue Aug 26, 2014 10:36 am Posts: 822 Location: Jefferson TX
or pull out sub floor, put 4x4 or 4x6 under boat where it is cupped or bent take another 4x4 or 4x6 and place over top of dents (both pieces should stick out past bottom and top of boat sides, use smaller blocks and a hydraulic bottle jack and push out dents to the bottom 4x4. no banging and less chance of breaking welds or cause cracks!
_________________ SEAARK FX 2472 CC Merc 150HP 4Stroke(CypressCadillac) Uncle J Custom - 19x54 CC Skiff w/40XD GTR
| Fri Sep 23, 2016 9:32 am |
nuccifish06
Joined: Tue Sep 16, 2014 6:36 pm Posts: 108 Location: Sunrise, FL
What happens if you repair a hook too much  ? I was hammering out the transom hook and hit one spot a bit too hard. How will a reverse hook effect the ride?
_________________ 1438 Jon / 23hp MBLT
| Fri Sep 23, 2016 9:42 am |
cb5331
| Fri Sep 23, 2016 9:46 am |
nuccifish06
lol. Good its a POS 1438 MBLT.
| Fri Sep 23, 2016 9:49 am |
JphIII
Applied Fasco fas stone 7 to some minor hooks and didn't help with my low rpm issue.
| Mon Sep 26, 2016 7:16 am |
