Cold weather cable lube http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=6838 |
Author: | sprig126 [ Thu Dec 31, 2009 6:49 am ] |
Post subject: | Cold weather cable lube |
Normally I lube the throttle cable with WD40(35 GTR stock cable on Mikuni carb). The temp dipped into the low 20's and the throttle cable was extemley stiff. After the hunt I removed throttle cable and flushed it with carb cleaner. It works better in the cold now but it would work better with some lube. I need to get a new cable soon anyway. But what can I use that wont gum up in the cold? |
Author: | 3peckeredbilly [ Thu Dec 31, 2009 10:15 am ] |
Post subject: | Re: Cold weather cable lube |
Quantum Hot Sauce Reel Lube. A little goes a long way. http://www.cabelas.com/p-0017253117468a.shtml |
Author: | deadbird8 [ Fri Jan 01, 2010 2:57 pm ] |
I use Corrosion X- helps keep the oxidation off it after running in salt too. |
