It is currently Mon Apr 06, 2026 1:30 am
Reply to topic  [ 1 post ]
 MM Clutch question
Post MM Clutch question
Started noticing a speed drop off during a hunt...the next day ruining to spot motor dropped out of gear. Took a look at clutch and noticed that the bolt holding clutch assembly on was torqued nowhere close to the 55lb specified. Looked further and found this pleasant site...would this be caused by an under torqued bolt alone? Motor has under 50 hrs use.
_________________________________
Alumacraft 1546 AW/Mudbuddy 27 Mini
Sun Sep 25, 2016 6:49 pm
