It is currently Mon Apr 06, 2026 2:44 pm
Reply to topic  [ 8 posts ]
 2008 mud buddy trailer pin
Post 2008 mud buddy trailer pin
does anyone have an older mud buddy with a push in trailer pin?
I have one and with multiple straps holding the motor down on the pin , it still manages to work it's way loose
bouncing around on the road the pin wiggles out and motor will drop when fully disengaged
I see the newer motors have pin that locks it in place, this motor has not room for a pin,
anyone have any luck with a better idea ?
Tue Sep 27, 2016 8:01 am
Post Re: 2008 mud buddy trailer pin
Maybe you can make something like this?
It'll lock it into place.
Tue Sep 27, 2016 8:08 am
I have a 2007 model and had the same issue. I ended up drilling a hole and using a hitch pin just like the picture and now it works great.
17 x 44 Southfork Mud Hull with a 25hp Big Block Mudbuddy
Tue Sep 27, 2016 10:56 am
where did you drill a hole? the round hand grab knob fits flush against the side of the housing, there is no kind of extension
off the side of the motor, to drill a hole thru.
or did you drill the pin inside some how, don't see how I could get to it,
I guess I could weld on a metal tab, and then pair drill them to fit a pin thru. the trailer pin
Tue Sep 27, 2016 11:33 am
Ahh. You'll have to take the concept and get creative since the collar isn't part of yours.
Tue Sep 27, 2016 12:10 pm
Weld a hinged "L" to the frame that flips out and sits against the ball. Use a zip tie, velcro strap, or rubber band that keeps the "L" from moving. It'll keep that pin from backing out.
Tue Sep 27, 2016 12:14 pm
I drilled through the outer collar and thru the pin at the same time. Get a carbide tipped drill bit and go easy with it using lots of cutting oil. Do not force it or you will end up breaking the bit off.
Wed Sep 28, 2016 10:34 am
replace it with one of these...
http://www.mcmaster.com/#standard-quick ... s/=14d85nw
Wed Sep 28, 2016 12:11 pm
