It is currently Thu Apr 09, 2026 4:26 pm
Reply to topic  [ 21 posts ]
 5500 Mag BAMF failure (2013 ym)
Post 5500 Mag BAMF failure (2013 ym)
I will make this short.
I purchased new did maintenance every 50 hours as instructed. Always ran 93+ octane.
Never had a single issue until tuesday....
I actually made a long run Sunday for a hunt with a sizable load parked in my driveway until tuesday....at first started it sounded horrible....decided to take it back to my shop and tear down....
See pictures.
My only conclusion not definitive...
A small piece of muffler got sucked into or bounced into #2 cylinder (while trailered)
Never heard a rattle before this I'm assuming muffler fell apart after my Sunday hunt.
Any insight or other thoughts are appreciated.
The "red" pieces of debris were removed from the muffler the "black" ones came out of the intake & exhaust ports on the head.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Thu Sep 15, 2016 8:40 pm
Post Re: 5500 Mag BAMF failure (2013 ym)
Thu Sep 15, 2016 8:41 pm
I think you diagnosed it correctly , that piece of baffle came apart and did exactly what you see. That sucks!.
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Thu Sep 15, 2016 8:50 pm
Looks quite familiar. Also on a 5500 bamf. He's likely sleeping by now (he's old and in the eastern time zone), but I'm sure he'll chime in tomorrow.
Thu Sep 15, 2016 9:00 pm
Bamf = broke ass mother fucker?
Thu Sep 15, 2016 9:06 pm
Once done fixing them, yes. Lmao
Thu Sep 15, 2016 9:21 pm
Fri Sep 16, 2016 6:26 am
That build recipe is not long for life and that is par for the course with muffler debris seen it many times it sucks
1754 With Level 3 GTR
Fri Sep 16, 2016 7:23 am
Muffler debris came out of duals? Doesn't seem possible with the turn downs. I mean the shit was obviously in there but I thought they were safe from that.
Fri Sep 16, 2016 7:46 am
Fri Sep 16, 2016 12:41 pm
Fri Sep 16, 2016 12:42 pm
My guess would be while being trailered. Do you trailer with it trimmed all the way up?
17.5x48 CC w/ PD 36 Gen 3 EFI E2
"They cant put anything on the internet that isn't true."
"Where'd you hear that?"
"The internet"
Fri Sep 16, 2016 3:05 pm
I had a stock exhaust come apart and drop a jewel down in a head and slam a plug shut once. Luckily on a stock motor still under warranty.
Had to have happened when trailering for me too.
Good luck man. That shit sucks!
Kool-Aid Brigade
www.southernfowler.com
Fri Sep 16, 2016 3:45 pm
Fri Sep 16, 2016 4:10 pm
Makes me wanna figure out how to travel with my GDSD trimmed down instead of up haha.. So if your exhaust is gutted should there be any pieces left to fall ?
Fri Sep 16, 2016 5:20 pm
Fri Sep 16, 2016 8:20 pm
Don't have this problem with a vertical shaft engine :mrgreen:
Fri Sep 16, 2016 8:26 pm
Finished putting it together on Wednesday. All looks good. Compression test is 250/244.
Tested dry....will test on water next week.
Fri Sep 30, 2016 9:40 pm
Dam that's some high compression!
Fri Sep 30, 2016 10:05 pm
I believe that is what Strobie22 meant by his comment.
GTR, Waitin' on a DFOU hull
Sat Oct 01, 2016 3:40 am
I've had that happen on 2 motors. It does cause the pissed off mode. Since I changed to MM exhaust I haven't had any more problems
Sat Oct 01, 2016 9:21 am
