| No gains! http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=68481 |
| Author: | Swampeast101 [ Sat Oct 01, 2016 7:38 pm ] |
| Post subject: | No gains! |
I modded my 32 hp prodrive this week. Heads decked .045, polished exhaust chamber and lightly hit the intake side, deltas oversized manley valves, deltas 305 cam and ported the intake manifold. Still running the stock carb. Also, mm xx exhaust. I have seen next to nothing in gains, maybe a little more torque getting on step but zero added rpms (4100)or speed. Im running a hopkins clever prop on a 1648 boat no load at 26 mph. Any body got any ideas or info? |
| Author: | JphIII [ Tue Oct 04, 2016 11:56 am ] |
| Post subject: | Re: No gains! |
Try different prop or work your current prop? |
| Author: | JphIII [ Tue Oct 04, 2016 2:00 pm ] |
Have you talked with Delta? |
| Author: | brycecheramie [ Tue Oct 04, 2016 5:01 pm ] |
| Author: | dead animal [ Tue Oct 04, 2016 5:09 pm ] |
mods only work on internet forums!!!!! lol |
| Author: | Will C [ Tue Oct 04, 2016 9:04 pm ] |
We recently put heads , exhaust and stock worked carb on a buddy's rig. Boat is a 1648 ribbed ol bass boat .Rpms went from 3700 to 4100's.went from 27 to 28 only. Much quicker boat but 28 with 1 0r 3 ppl. Boat drags water bad. What hull you running? Btw you are probly lean on fuel |
| Author: | MaXXis85 [ Wed Oct 05, 2016 6:06 am ] |
Make sure you correct the governor setting to at least 4750-4800 in neutral so it is NOT hindering your performance. You should see close to 4500 RPM |
| Author: | caddobrook [ Wed Oct 05, 2016 7:34 am ] |
| Author: | duckduckboom [ Wed Oct 05, 2016 12:47 pm ] |
Did you forget to put the performance stickers on? |
| Author: | Swampeast101 [ Wed Oct 05, 2016 5:13 pm ] |
It was the stickers. I slapped one on the cowl and instantly got 4500 rpms! Haha, nah i did order a lectron today though. Im over piddling with this cotton pickin governor! |
| Author: | MaXXis85 [ Thu Oct 06, 2016 5:43 am ] |
| Author: | Delta Performance [ Thu Oct 06, 2016 6:32 am ] |
It's the spring! It's sickening when you build one the way yours is built with stock carb and someone forgets to put the new spring on and it only makes 38 HP on the Dyno. Change spring and it make 45 Sent from my iPhone using Tapatalk |
| Author: | MaXXis85 [ Thu Oct 06, 2016 7:35 am ] |
