Carb adjment Vanguard 31 http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=6876 |
Author: | kevin burroughs [ Sat Jan 02, 2010 8:57 pm ] |
Post subject: | Carb adjment Vanguard 31 |
I just put the dual exhaust kit on a buddies MB 31 Vanguard. It seems like it is running a little lean at idle and mid range now. It has a Nikki carb on it. I'm looking for the idle mixture adjustment. I own a garage and can set mixture with my 5 gas analyzer, I just can't find where to adjust it. -----------kevin---------- |
Author: | deadbird8 [ Mon Jan 04, 2010 1:17 pm ] |
Post subject: | Re: Carb adjment Vanguard 31 |
Don't think the 31 has idle mix adjust on the carb. You can put a 35 carb on it- same fit as the 31. |
Author: | rebbeer [ Mon Jan 04, 2010 4:04 pm ] |
If you go to mudbuddy.com, they sell the stock 35 carbs for something like $85. |
Author: | kevin burroughs [ Wed Jan 06, 2010 10:50 pm ] |
Thanks for the info guys. I also learned that you have to check the coils in the mag for proper adjustment. It seems that some were not even close from the factory. ---------kevin--------- |
