| Cross threaded bolt on 2015 gatortail 37 http://mudmotortalk.com/mmt_v2/viewtopic.php?f=3&t=68770 |
| Author: | dlegendp [ Fri Oct 28, 2016 3:03 pm ] |
| Post subject: | Cross threaded bolt on 2015 gatortail 37 |
I cross threaded the grease bolt on my motor. Any suggestions on getting it out. Sent from my iPhone using Tapatalk |
| Author: | flint87 [ Fri Oct 28, 2016 3:22 pm ] |
| Post subject: | Re: Cross threaded bolt on 2015 gatortail 37 |
Turn it left? Sent from my iPhone using Tapatalk |
| Author: | flint87 [ Fri Oct 28, 2016 3:23 pm ] |
Seriously though. Damage is done. Take it out and run a tap thru to clean up the threads. That or throw the shit fuckin thing away. Sent from my iPhone using Tapatalk |
| Author: | dlegendp [ Fri Oct 28, 2016 3:35 pm ] |
[quote="flint87"]Seriously though. Damage is done. Take it out and run a tap thru to clean up the threads. That or throw the shit fuckin thing away. Thanks. That's what I was thinking. Sent from my iPhone using Tapatalk |
| Author: | Duckslayer5200 [ Fri Oct 28, 2016 4:01 pm ] |
| Author: | dpd [ Fri Oct 28, 2016 4:13 pm ] |
What flint said. The bolt and the hole may be bad . If retapping and cleaning the bolt hole up doesn't work what I usually do is tap the hole the next size larger. Regardless start with a new bolt if you can Maybe somebody else has a better idea Been there done that |
| Author: | BERNIE255 [ Fri Oct 28, 2016 4:55 pm ] |
Easy out? Sent from my iPhone using Tapatalk |
| Author: | duck_watcher12 [ Sat Oct 29, 2016 7:28 pm ] |
Good pair of vise grip pliers should get it out |
| Author: | MALLARDSX2 [ Sun Oct 30, 2016 7:28 am ] |
TORCH THAT BITCH! |
| Author: | brycecheramie [ Sun Oct 30, 2016 8:10 am ] |
My goodness.... Next question will be how to take the damn grease gun off the grease zerk after pumping grease. |
| Author: | SETx Longtail [ Sun Oct 30, 2016 8:12 am ] |
It's getting bad isn't it |
| Author: | brycecheramie [ Sun Oct 30, 2016 8:15 am ] |
| Author: | dead animal [ Sun Oct 30, 2016 12:36 pm ] |
X2 on the turn left thing. why don't u just leave the sombitch like it is? |
| Author: | BERNIE255 [ Sun Oct 30, 2016 5:46 pm ] |
| Author: | brycecheramie [ Sun Oct 30, 2016 11:39 pm ] |
| Author: | BERNIE255 [ Mon Oct 31, 2016 8:19 pm ] |
I never herd them called grease zerks until i came on here, I always called them alemites Sent from my iPhone using Tapatalk |
| Author: | dlegendp [ Thu Nov 03, 2016 7:52 pm ] |
Got it out. It would not turn. Had to drill it out. I got lucky and I didn't mess up the threads. I didn't realize I needed a more complex issue to ask for advice. Sent from my iPhone using Tapatalk |
| Author: | MaXXis85 [ Fri Nov 04, 2016 5:54 am ] |
That is a pipe thread plug. Are the threads messed up or just the bolt head rounded off? |
| Author: | dlegendp [ Mon Nov 07, 2016 7:54 am ] |
I got it fixed. It is 1/8" pipe thread plug. I crossed it bad and had to drill it out. I used a smaller bit and when it was almost completely drilled it started turning. The threads were damaged but I retapped them and the same size plug fits. Sent from my iPhone using Tapatalk |
