It is currently Thu Apr 02, 2026 12:42 am
Reply to topic  [ 5 posts ]
 Exhaust Temp??
Post Exhaust Temp??
I have a 2008 PD 36 with mods..mikuni, head work ect. I gutted the can, and welded on a larger exhaust pipe. Im running lean.. does anyone know the exhaust, and head temps???
Thu Apr 27, 2017 6:33 am
Post Re: Exhaust Temp??
How do you know its lean? I would verify with an AFR meter.
Thu Apr 27, 2017 7:23 am
Or at minimum read the plugs after a wot run
Thu Apr 27, 2017 8:05 am
Also when you weld the exhaust tip on you need to reinforce that area with an extra layer. Ive seen 3 gutted stockers that the tips fell off from being very hot. When u gut one both exhaust flames are aimed right at the tail pipe area and will cook it
Thu Apr 27, 2017 9:27 am
https://youtu.be/3qIblmpJc9Y
Thu Apr 27, 2017 7:02 pm
